smog pump delete 1976 2.0 cali car |
dax1969 |
Dec 14 2017, 07:08 AM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Hi guys,
Tried the search option but can't find what I'm looking for. I know that the Cali 1976 914 2.0 has a smog pump/system to pass emission test. If such a system is not needed in your area, would you remove it or leave in place ? Will you gain more power without this system ? If you remove the pump should you only block of the lines with caps you can buy at AA or else or are there any other modifications needed ? Other exhaust ? thks yr advise krgds Dax |
914werke |
Dec 14 2017, 05:34 PM
"I got blisters on me fingers" Group: Members Posts: 10,067 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Remove the belt, but also cap off the ports at the heads. Backdate the exhaust. Will need earlier style heat exchangers and muffler. ...& air guide tin and hanger and j tubes and ....ect. (IMG:style_emoticons/default/smile.gif) |
mepstein |
Dec 14 2017, 05:46 PM
914-6 GT in waiting Group: Members Posts: 19,273 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Remove the belt, but also cap off the ports at the heads. Backdate the exhaust. Will need earlier style heat exchangers and muffler. ...& air guide tin and hanger and j tubes and ....ect. (IMG:style_emoticons/default/smile.gif) early cable |
Lo-Fi Version | Time is now: 18th May 2024 - 12:20 PM |
