adjusting valves, tdc help...thanks |
joeav8tor |
May 28 2005, 09:04 AM
Member Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
hi,
I reinstalled my head, and changed my pushrod tube seals (viton), and I am going to adjust my valves. I see a zero on the fan under the inspection cap...is this TDC for #1+#3?...i8o degrees out I see a tick mark on the flywheel under the tranny...is this TDC for #2+#4? my distributor is out of the car so I am doing it this way... I adjusted #1, rotated the engine and valves were very loose, I readjusted them, rotated the engine and they were fine....adjusted the valves on #2 (tick mark under tranny) rotated the engine, the valves were very loose...readjusted them, rotated the engine and they were tight (no clearance)....any suggestions thanks (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Joe |
SLITS |
May 28 2005, 09:09 AM
When I get tired of putzing with the marks, I simply do an "opposite valve" procedure. When a valve is fully open on one side, I adjust it's opposite...each lobe operates two valves. Takes a little longer, but I don't have to rely on marks.
joeav8tor |
May 28 2005, 02:04 PM
a little help here would be greatly appreciated!
(IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) Danka Joe |
SLITS |
May 28 2005, 02:27 PM
Joe, just not sure what you are asking for...previous post gave you a method without regard to timing marks (they can be off anyway) Do a search.,....Cap'n Krusty wrote a whole thread about his method. |
Lo-Fi Version | Time is now: 19th May 2024 - 11:33 PM |
