Tesla rear end swap |
siverson |
Dec 14 2017, 04:50 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
I think this has been done in VW buses, sand rails, and a Cobra - could be neat in a 914. And it would likely be a massive improvement over the rear suspension geometry as well.
Rear Track of a Model S is 67", Factory 914 is 55" - nothing some wide flares can't accommodate. -Steve |
Andyrew |
Dec 14 2017, 11:37 PM
If it were me I would not bother with trying to reinvent the rear of the 914. Using the tesla motor and trans would be small enough to fit in the 914 under the trunk. Some custom axles and away you go.
Would be a very simple mechanical swap, then your just left with a standard run of then mill EV swap and mounting as many batteries as you can afford (the real hinderance here). Probably easily spend 30k on this conversion, but hey you would have a pretty decent EV 914 that could run for likely hundreds of miles and be as fast as the fastest 914s out there. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:14 PM |
