Is this the right gas cap?, seems to leak |
98101 |
Dec 14 2017, 07:06 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I finally put enough miles on this new-to-me 1970 914-4 to refuel it. Since then I've noticed a strong gasoline smell after hard acceleration. I've tried fiddling with the gas cap to get it to seal better, but I'm also wondering if it's the correct one for the car. Many years ago I had a 1975 and 1973 and don't remember the gas cap looking like this.
Dave_Darling |
Dec 14 2017, 07:22 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The 75 cap would have been different. The 73 cap would have been like this--but someone painted this one.
I believe there is a seal on the underside of the cap; it can fail after a few decades. Double-check your charcoal canister lines. If they are unplugged they can lead to a gas smell. I think there is a gasket between the fuel filler neck assembly and the tank. A leak there might possibly give you a fuel smell too. The tank often rusts where it rests on the shell of the car--there are felt pads that can trap moisture and lead to pinholes. --DD |
mepstein |
Dec 14 2017, 07:39 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The 75 cap would have been different. The 73 cap would have been like this--but someone painted this one. I believe there is a seal on the underside of the cap; it can fail after a few decades. Double-check your charcoal canister lines. If they are unplugged they can lead to a gas smell. I think there is a gasket between the fuel filler neck assembly and the tank. A leak there might possibly give you a fuel smell too. The tank often rusts where it rests on the shell of the car--there are felt pads that can trap moisture and lead to pinholes. --DD And a third seal under the fuel tank sender. Also make sure the large clear overflow line exits out from under the car. |
Lo-Fi Version | Time is now: 9th May 2024 - 02:36 AM |
