Engine Options, Build 2.3 or pursue other options |
Mblizzard |
Dec 15 2017, 05:27 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I currently have a 2056 with a great top half. Big valve heads, Micro Squirt, and 96mm P/Cs. But I want more HP. I have set myself a $4K budget for building the bottom half, potentially going to 2.3 with a stroker crank, adding cam, balancing, and making some valve train improvements. But I started thinking, you know how dangerous that is, are there any other engine options in the $4K range that would provide reasonable HP increase. Not looking for 250 HP but just enough to keep it interesting.
Anyone got thoughts or suggestions? Open to most options but not sure that converting to water cooled is even remotely possible with the budget limit. Engine swap for proven HP increase seems the easiest option but thought I would see what the brain trust could come up with. |
Mark Henry |
Dec 15 2017, 06:53 PM
Since you have already done all the hard work for a T4 I'd stick with it.
A stroker would fall in that range if DYI and using the goodies you have. Pistons are a no go... 78mm crank with T1 rods journals, clearanced CB rods and KB pistons. You need a reduced circle cam. I think all the WC options start around $5K minimum unless you are super handy in the fab department. Also are you totally sorted in the handling dept? I'd take care of that first. |
Lo-Fi Version | Time is now: 30th April 2024 - 12:47 AM |
