Engine Options, Build 2.3 or pursue other options |
Mblizzard |
Dec 15 2017, 05:27 PM
I currently have a 2056 with a great top half. Big valve heads, Micro Squirt, and 96mm P/Cs. But I want more HP. I have set myself a $4K budget for building the bottom half, potentially going to 2.3 with a stroker crank, adding cam, balancing, and making some valve train improvements. But I started thinking, you know how dangerous that is, are there any other engine options in the $4K range that would provide reasonable HP increase. Not looking for 250 HP but just enough to keep it interesting.
Anyone got thoughts or suggestions? Open to most options but not sure that converting to water cooled is even remotely possible with the budget limit. Engine swap for proven HP increase seems the easiest option but thought I would see what the brain trust could come up with. |
DaveO90s4 |
Dec 21 2017, 02:54 PM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
I have a full marching numbers 1956 356A. I think it likely that in 20 years time when my 914 is of the age my 356 is now, matching numbers might be important.
But I wanted more get up and go now. So I removed the 1.8 engine and that will now never break a rod etc while tucked under my workshop bench. And I installed a 140 HP air cooled chev Corvair reverse rotation engine. It fits with no body modifications what so ever. Front engine mount does not involve welding on firewall. So it is all 100% reversible back to stock - one day. The acceleration is on par with my 3.2 L Carrera. And engines and parts are cheap too - unlike a Porsche 6. Worth thinking about maybe?? DaveO |
Robnxious |
Dec 21 2017, 05:43 PM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
I have a full marching numbers 1956 356A. I think it likely that in 20 years time when my 914 is of the age my 356 is now, matching numbers might be important. But I wanted more get up and go now. So I removed the 1.8 engine and that will now never break a rod etc while tucked under my workshop bench. And I installed a 140 HP air cooled chev Corvair reverse rotation engine. It fits with no body modifications what so ever. Front engine mount does not involve welding on firewall. So it is all 100% reversible back to stock - one day. The acceleration is on par with my 3.2 L Carrera. And engines and parts are cheap too - unlike a Porsche 6. Worth thinking about maybe?? DaveO The quote "never break a rod while tucked under my work bench" is precisely why I got a new case and had the 2.3 built from the case up and am keeping the other engine. I could just see going big w/ adding onto the engine, and "BAM" there goes my numbers matching engine |
Lo-Fi Version | Time is now: 29th March 2024 - 01:40 AM |
