Engine Options, Build 2.3 or pursue other options |
Mblizzard |
Dec 15 2017, 05:27 PM
I currently have a 2056 with a great top half. Big valve heads, Micro Squirt, and 96mm P/Cs. But I want more HP. I have set myself a $4K budget for building the bottom half, potentially going to 2.3 with a stroker crank, adding cam, balancing, and making some valve train improvements. But I started thinking, you know how dangerous that is, are there any other engine options in the $4K range that would provide reasonable HP increase. Not looking for 250 HP but just enough to keep it interesting.
Anyone got thoughts or suggestions? Open to most options but not sure that converting to water cooled is even remotely possible with the budget limit. Engine swap for proven HP increase seems the easiest option but thought I would see what the brain trust could come up with. |
rhodyguy |
Dec 21 2017, 04:01 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,055 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What is the plan for cylinders?
Mblizzard |
Dec 21 2017, 05:00 PM
Mark Henry |
Dec 21 2017, 07:55 PM
What is the plan for cylinders? Right now I am looking at keeping my 96mm. But I am struggling in not totally sink my budget and go with some LN Nickies 103 mm. I don't really need massive HP numbers I want usable torque. Lots of it! Nickies would blow your budget and IMO a waste of time if not doing a stroker, I don't even know if you can get them with the T4 24mm rod pin. I'd do a stroker with iron cylinder 96's before I'd consider a stock stroke 103 engine. |
Lo-Fi Version | Time is now: 19th April 2024 - 06:15 PM |
