Engine Options, Build 2.3 or pursue other options |
Mblizzard |
Dec 15 2017, 05:27 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I currently have a 2056 with a great top half. Big valve heads, Micro Squirt, and 96mm P/Cs. But I want more HP. I have set myself a $4K budget for building the bottom half, potentially going to 2.3 with a stroker crank, adding cam, balancing, and making some valve train improvements. But I started thinking, you know how dangerous that is, are there any other engine options in the $4K range that would provide reasonable HP increase. Not looking for 250 HP but just enough to keep it interesting.
Anyone got thoughts or suggestions? Open to most options but not sure that converting to water cooled is even remotely possible with the budget limit. Engine swap for proven HP increase seems the easiest option but thought I would see what the brain trust could come up with. |
Mark Henry |
Dec 21 2017, 08:12 PM
I've built a bunch of nickies engines, /4, /6 and 996... I can tell you to do it right it's not cheap.
I'm an LN dealer, my '67 bug is a T4 conversion with a 78 x 102mm engine. Slightly off topic, but has everyone else noticed that the Type 4 Store is ONLY selling Nickies now as part of their engine kits? Likely they want you to use the correct parts and combo. I can get them without the kit. |
Lo-Fi Version | Time is now: 25th April 2024 - 07:02 PM |
