Engine Options, Build 2.3 or pursue other options |
Mblizzard |
Dec 15 2017, 05:27 PM
I currently have a 2056 with a great top half. Big valve heads, Micro Squirt, and 96mm P/Cs. But I want more HP. I have set myself a $4K budget for building the bottom half, potentially going to 2.3 with a stroker crank, adding cam, balancing, and making some valve train improvements. But I started thinking, you know how dangerous that is, are there any other engine options in the $4K range that would provide reasonable HP increase. Not looking for 250 HP but just enough to keep it interesting.
Anyone got thoughts or suggestions? Open to most options but not sure that converting to water cooled is even remotely possible with the budget limit. Engine swap for proven HP increase seems the easiest option but thought I would see what the brain trust could come up with. |
Montreal914 |
Dec 21 2017, 08:37 PM
Senior Member Group: Members Posts: 1,532 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
As Mark mentioned, if you stay in the budget range and use the KB pistons, you will want to use different ones than the ones on your 2056. KB has the ones with higher pin location for stroker application.
Mark, when you mentioned Web 163/86a, did you mean 163/86b? (IMG:style_emoticons/default/confused24.gif) Sound like a very cool project, like your MS upgrade, I will definitely follow. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 29th March 2024 - 02:25 AM |
