Fuchs education |
Fuchs education |
Cal |
Dec 16 2017, 09:58 AM
Senior Member Group: Members Posts: 614 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
I'm considering doing a 5-lug conversation to my '74 2.0L using Eric Shea's kit from PMB. I'd prefer this option because I can easily convert it back to the 4-lug if needed. There are a number of replica Fuchs available from Maxilite that look pretty good....15x6 (deep 6), 15x7R and the standard 15x7. The offsets on each of these wheels is different ET36, ET47 & ET23.3.....are there advantages/disadvantages with each? What would be the safest tire width that could be run on each of these wheels without modifying the bodywork on the car.....would 195/65/15 be a safe bet? The photo below would be the ideal look that I'm looking for....15x7 with the RS or RSR finish. I'm open for suggestions / opinions.
Attached thumbnail(s) |
GeorgeRud |
Dec 16 2017, 10:07 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
195/65-15 fit nicely and have a proper vintage look. 205s can sometimes fit. Eric’s conversion kit will certainly be the easiest way to get all the proper parts for the conversion. 6” wide Fuchs (or replicas) fit very easily, though folks have fit 7” wide wheels if they have the proper ET (backspacing) to prevent the tires from rubbing the fenders. There is some variability on the fender clearance from car to car (and even from side to side on the same car), so going a bit conservative is safer. You can always use some spacers if you decide to increase the track if desired.
Lo-Fi Version | Time is now: 28th April 2024 - 03:38 AM |
