Fuchs education |
Fuchs education |
Cal |
Dec 16 2017, 09:58 AM
Senior Member Group: Members Posts: 615 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
I'm considering doing a 5-lug conversation to my '74 2.0L using Eric Shea's kit from PMB. I'd prefer this option because I can easily convert it back to the 4-lug if needed. There are a number of replica Fuchs available from Maxilite that look pretty good....15x6 (deep 6), 15x7R and the standard 15x7. The offsets on each of these wheels is different ET36, ET47 & ET23.3.....are there advantages/disadvantages with each? What would be the safest tire width that could be run on each of these wheels without modifying the bodywork on the car.....would 195/65/15 be a safe bet? The photo below would be the ideal look that I'm looking for....15x7 with the RS or RSR finish. I'm open for suggestions / opinions.
Attached thumbnail(s) |
HansJan |
Dec 17 2017, 12:32 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
DRPHIL914 |
Dec 19 2017, 01:30 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
After screwing around with bigger tires I ended up with 205-55-R16 on 7” Fuchs all around. Totally fills up the wheel-well. It’s all personal preference, and what ever you decide to do it can be reversed easily. I have 205/55 16 on my 7" rear, 6"wide front- the 7" rubbed in rear, not in front- blistered my paint and rolled fenders were a disaster that had to be repaired, now the 7" fit but still so close - its not worth it- cars vary , one car may fit but mine did not - I put the 6" in front and have 1/2" spacers and no rubbing looks great - the rear 7" will come off before I paint and will get same bridgestone Potenza performance tire on 6", and I can put 1/2 spacers on them and still have plenty of room because the offset on a 6 vs 7 is all from center out, not in. SO if you have new paint , stay with the 6" rims- you only loose like a 1/2" of tread width not stretching them across a 7" rim - the tire width of the Potenza on the ground is more than 7" when mounted on a 6" rim. Phil |
Lo-Fi Version | Time is now: 8th May 2024 - 01:35 PM |
