Fuchs education |
Fuchs education |
Cal |
Dec 16 2017, 09:58 AM
Senior Member Group: Members Posts: 614 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
I'm considering doing a 5-lug conversation to my '74 2.0L using Eric Shea's kit from PMB. I'd prefer this option because I can easily convert it back to the 4-lug if needed. There are a number of replica Fuchs available from Maxilite that look pretty good....15x6 (deep 6), 15x7R and the standard 15x7. The offsets on each of these wheels is different ET36, ET47 & ET23.3.....are there advantages/disadvantages with each? What would be the safest tire width that could be run on each of these wheels without modifying the bodywork on the car.....would 195/65/15 be a safe bet? The photo below would be the ideal look that I'm looking for....15x7 with the RS or RSR finish. I'm open for suggestions / opinions.
Attached thumbnail(s) |
Racer |
Dec 18 2017, 06:23 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
find a 6x15.. deep or flat.. and if you want to fill out the fenderwells, add 1/4" spacers till you rub. 205/50 or 195/60. Considering how sticky modern tires are, you don't really need to cram anything larger than a 205 unless you are running some serious hp.
if on a budget, then look for 6x15 cookies as they haven't been completely priced to oblivion like Fuchs have. or go period correct alternate and get some 6.5x15 Minilites instead! QUOTE different ET36, ET47 & ET23.3 ET36 is what you want. ET 49 (911R) means that the extra width (7" vs 6") is carried to the "inside" of the fenderwell. So , when comparing a 7x15 et 23 vs a 7x15 et49, the 23 will have a "dish" whereas the 49 will look like a 6". An alternative look would be 7x15 phonedials, available in both et23 and 52 for cheap. |
Lo-Fi Version | Time is now: 26th April 2024 - 05:11 AM |
