Timing w/ carbs, where to set? |
akellym |
May 28 2005, 12:37 PM
Eyes Of The Deep Battle Group: Members Posts: 597 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region |
I have 73 1.7 w/ the 1.8 big bore kit that I have put dual 34 carbs on and have changed the dist. to a 009. I'm not sure where to set the timing.
SLITS |
May 28 2005, 02:23 PM
27 degrees at 3000 rpm.....doesn't change.
Cap'n Krusty |
May 28 2005, 02:38 PM
Actually, you can go to 30 degrees total advance. 32 MIGHT be OK, but you need to be REAL careful you don't get pinging.
This means you'll be at between 13 and 15 degrees BTDC at idle, because the less-than-desirable POS 009 has only about 17 degrees total advance. The Cap'n |
akellym |
May 28 2005, 03:02 PM
thanks! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 11:08 PM |
