staggered wheels ? (on a "gt flared car"), any real benefits? |
larryM |
Dec 20 2017, 02:41 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
just curious (IMG:style_emoticons/default/confused24.gif)
- for those who are running staggered rear/front wheels on flared cars - AND who have also run all-same size - without modifying the other suspension factors ? what are your comparative experiences & tho'ts about any handling benefits or detriments, given that our cars are quite well F/R weight balanced street vs AX vs track???? - 3 distinctly different ways we "use" the cars i know the "le mans" cars used stagger, .... did the rallye cars such as monte-carlo, or many of the other racers back in the 70-73 period (does the Roy Smith "racing 914's" book give us that info?? - iirc the factory FIA spec GT wheel was 15x7 all around (fuchs 8x15 were not made then), and the "gt" cars at RRV all were running 15x8s iirc - historic venue rules being a factor concerning plus sizes (fwiw imle - staggered sizes limit ability to cross rotate for tire wear for non-directional street tires on my car with competition neg-camber alignment - i did run staggered sizes when racing, but never all-same, so can't say if it might have made any difference - & can't say i can tell any difference when "canyon carving" on street tires either way) i posted a similar Q on pelican, but those opinions are mostly about 911s which are notoriously in need of such "help" - (i owned a swb 911 - know all about that evil) http://forums.pelicanparts.com/porsche-911...tire-sizes.html |
914Toy |
Dec 20 2017, 03:47 PM
Senior Member Group: Members Posts: 715 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
just curious (IMG:style_emoticons/default/confused24.gif) - for those who are running staggered rear/front wheels on flared cars - AND who have also run all-same size - without modifying the other suspension factors ? what are your comparative experiences & tho'ts about any handling benefits or detriments, given that our cars are quite well F/R weight balanced street vs AX vs track???? - 3 distinctly different ways we "use" the cars i know the "le mans" cars used stagger, .... did the rallye cars such as monte-carlo, or many of the other racers back in the 70-73 period (does the Roy Smith "racing 914's" book give us that info?? - iirc the factory FIA spec GT wheel was 15x7 all around (fuchs 8x15 were not made then), and the "gt" cars at RRV all were running 15x8s iirc - historic venue rules being a factor concerning plus sizes (fwiw imle - staggered sizes limit ability to cross rotate for tire wear for non-directional street tires on my car with competition neg-camber alignment - i did run staggered sizes when racing, but never all-same, so can't say if it might have made any difference - & can't say i can tell any difference when "canyon carving" on street tires either way) i posted a similar Q on pelican, but those opinions are mostly about 911s which are notoriously in need of such "help" - (i owned a swb 911 - know all about that evil) http://forums.pelicanparts.com/porsche-911...tire-sizes.html Convenience of same size wheel/tire for non-track competitive but street "spirited" driving with adequate street tire is all you will ever need. Adequate street depends on a lot of factors, but 7" wide wheels with well fitting tires is probably a good starting point. Now cool factor is another matter (IMG:style_emoticons/default/beer.gif) |
jd74914 |
Dec 20 2017, 03:57 PM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I'm not sure there is an issue running the same sizes-until tire temperatures get out of whack. Even street tires have an idea tire temperature for best rubber grip. When the tires are cold, having extra wide stuff in the back probably doesn't make a difference since friction coefficient is overall insensitive to surface area. As you really work the tires (staying at the edges of that friction circle Bill is talking about), you're adding energy to the carcass. A wider tire can handle that energy addition better because it has more mass and more surface area to dissipate energy. There should be a perfect front and rear tire size to keep the tire temperatures acceptable for the compound.
For a street car, you're probably never really working the tires so I bet it doesn't matter. But perhaps if you are really driving for a bit there could be a definitive benefit? |
brant |
Dec 20 2017, 04:00 PM
914 Wizard Group: Members Posts: 11,607 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I believe the lemans cars actually used 6inch wheels with a 1 inch spacer
sure by the later 70's wider wheels were common but in the early 70's they were not I think I have an FIA appendix J at home for the lemans cars its in german... but has all of the black and white photo's of what the FIA ACTUALLY accepted in 1970 brant |
Dec 20 2017, 04:01 PM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Some unverified thoughts:
7” on the front will steer lighter than an 8” 8” on the back for the 3.2 engine Definitely looks good Our tires tend to age out before worn out Eric Shea told me to do it that way (IMG:style_emoticons/default/biggrin.gif) |
Mark Henry |
Dec 20 2017, 04:54 PM
Mid engine car I was always told there wasn't much if any advantage.
I can see the lighter steering, but wouldn't that be more a low speed advantage? BTW I asked the same thing back in early 2000. |
Chris914n6 |
Dec 20 2017, 05:54 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
The car is balanced with same size tires.
Fatter rears are to compensate for more HP. The harder steering is more a factor of the spacers pushing the wheel centers out than 20mm more tire. I've currently running stock Boxsters. 16x6 w/205 and 16x7 w/225. When I need to replace the tires I've been considering 225/45 on a set of Euromeister 17x7 just to get the natural balance back. 200hp isn't swinging the rear out like a Mustang. |
larryM |
Dec 23 2017, 12:20 AM
The Info for Sports Purposes document 4890.20-200-03-72 (see page 33-35) shows the 914/6 (on all 4, not staggered) 6"x15 for rallye, with tires spec 185/70-15;
and 7"x15 wheels for racing with racing tires spec 4.75/10.00-15 (same as on 917 www.flickr.com/photos/wbaiv/6252749070) Info Sports Purposes to 1972 - https://www.dropbox.com/home/914-6-GT%20his...972_english.pdf (on my dropbox pages) - the 914/6 (flared GT) was spec'd for 21mm spacers with the 6's, and 27F/35mmR for the 7's (... also spec'd long studs & steel lugnuts for racing) as a general rule - 7x15's were the FIA homologation spec as seen in the "factory docs" let's also remember that the "Porsche spec performance tire" of 1970 was a 185/70xVR15 for both the 911 & 914/6 - IIRC the Sunoco GT used wider non-Fuchs (minilite?) rear wheels 'cuz ther was no 8" Fuchs then (the French car Ranson Webster now owns & races 9140430457 - had them when i saw it in his showroom a few yrs ago; at RRV it had fuchs on back! http://www.914-6-club.de/PorscheClubs/pc_9...nt&tabnr=2) SCCA GCR up to 1972, generally allowed 1" wider than FIA spec; so 8x15 would have been period OK; in the 1972 GCR they went up to 1.5" wider, but limited overall track width in both cases ... "1971 GCR stock 914/6 spec was 6x15" .... 53.58 frt, 54.41 rear track width" - on some cars, careful selection of width/backspace can yield wider wheels & slightly more contact patch - so that's probably why most vintage/historic groups & PCA allow up to 8x15's - but no x16 dia HMSA (& other Steve Earle venues) upon petition, allowed 914/6's pure slicks on x15s (see Jon Wactor 9140430375 and Eddie Arrowsmith both running Goodyear cantilevers) because the 4.75/10's were allowed per factory 4890.20-200-03-72 the 1972 m471 "USA dealer option" only suggested 6x15's (pic) below fwiw - to corroborate a comment above: circa 1993 Ken Mack founder of Sportech in Campbell who was a credible 914/6 racer for some yrs, said "7x16 with 225/50 frt, 8x16 rear with 245/45" so i b'ot a set of 16" BBS-RA from him to that end - obviously not "period correct" -he aligned my car to comp'tn spec & i have never changed that (still have the wheels) - dunno if it made a diff since i never ran anything else after that (ran 8x15/9x15 BBS before that - also vintage incorrect, but scca scrutineers never looked at 'em except to see if the steel lugnuts were tight) & i also converted my frt-susp to 911 SC with underslung swayvbar on advise of another P-car guru i currently run 4 7x16 fuchs with A/S3s all around - (let's me cross rotate for better street tire wear cuz the comp'tn negative camber is an issue, as another above post suggests) - i briefly tried 8x16 rear fuchs with 245/45 last yr, it "felt different" but the like-new Fusions were 10yrs old, so my seat-of-pants opinion is irrelevant; (i dismounted 'em & you can have 'em for free at my gate zip 95635) - back to the original question - do any of us have experience that suggests wider rear wheels & fatter-lower-profile tires make any difference on (any) 914? (IMG:style_emoticons/default/cheer.gif) yes - i have copies of all this historic stuff - but am finding it is difficult to scan & convert some of 'em to something i can post - |
larryM |
Dec 23 2017, 12:21 AM
Mid engine car I was always told there wasn't much if any advantage. I can see the lighter steering, but wouldn't that be more a low speed advantage? BTW I asked the same thing back in early 2000. got a link to that - might be interesting to review the comments |
mlindner |
Dec 23 2017, 05:17 AM
Senior Member Group: Members Posts: 1,509 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
The Info for Sports Purposes document 4890.20-200-03-72 (see page 33-35) shows the 914/6 (on all 4, not staggered) 6"x15 for rallye, with tires spec 185/70-15; and 7"x15 wheels for racing with racing tires spec 4.75/10.00-15 (same as on 917 www.flickr.com/photos/wbaiv/6252749070) Info Sports Purposes to 1972 - https://www.dropbox.com/home/914-6-GT%20his...972_english.pdf (on my dropbox pages) - the 914/6 (flared GT) was spec'd for 21mm spacers with the 6's, and 27F/35mmR for the 7's (... also spec'd long studs & steel lugnuts for racing) as a general rule - 7x15's were the FIA homologation spec as seen in the "factory docs" let's also remember that the "Porsche spec performance tire" of 1970 was a 185/70xVR15 for both the 911 & 914/6 Wow, thats a lot of nice information larrym. Thanks for sharing. Mark - IIRC the Sunoco GT used wider non-Fuchs (minilite?) rear wheels 'cuz ther was no 8" Fuchs then (the French car Ranson Webster now owns & races 9140430457 - had them when i saw it in his showroom a few yrs ago; at RRV it had fuchs on back! http://www.914-6-club.de/PorscheClubs/pc_9...nt&tabnr=2) SCCA GCR up to 1972, generally allowed 1" wider than FIA spec; so 8x15 would have been period OK; in the 1972 GCR they went up to 1.5" wider, but limited overall track width in both cases ... "1971 GCR stock 914/6 spec was 6x15" .... 53.58 frt, 54.41 rear track width" - on some cars, careful selection of width/backspace can yield wider wheels & slightly more contact patch - so that's probably why most vintage/historic groups & PCA allow up to 8x15's - but no x16 dia HMSA (& other Steve Earle venues) upon petition, allowed 914/6's pure slicks on x15s (see Jon Wactor 9140430375 and Eddie Arrowsmith both running Goodyear cantilevers) because the 4.75/10's were allowed per factory 4890.20-200-03-72 the 1972 m471 "USA dealer option" only suggested 6x15's (pic) below fwiw - to corroborate a comment above: circa 1993 Ken Mack founder of Sportech in Campbell who was a credible 914/6 racer for some yrs, said "7x16 with 225/50 frt, 8x16 rear with 245/45" so i b'ot a set of 16" BBS-RA from him to that end - obviously not "period correct" -he aligned my car to comp'tn spec & i have never changed that (still have the wheels) - dunno if it made a diff since i never ran anything else after that (ran 8x15/9x15 BBS before that - also vintage incorrect, but scca scrutineers never looked at 'em except to see if the steel lugnuts were tight) & i also converted my frt-susp to 911 SC with underslung swayvbar on advise of another P-car guru i currently run 4 7x16 fuchs with A/S3s all around - (let's me cross rotate for better street tire wear cuz the comp'tn negative camber is an issue, as another above post suggests) - i briefly tried 8x16 rear fuchs with 245/45 last yr, it "felt different" but the like-new Fusions were 10yrs old, so my seat-of-pants opinion is irrelevant; (i dismounted 'em & you can have 'em for free at my gate zip 95635) - back to the original question - do any of us have experience that suggests wider rear wheels & fatter-lower-profile tires make any difference on (any) 914? (IMG:style_emoticons/default/cheer.gif) yes - i have copies of all this historic stuff - but am finding it is difficult to scan & convert some of 'em to something i can post - |
mlindner |
Dec 23 2017, 05:19 AM
LarryM, wow thats a lot of great information. Thanks for sharing. Best, Mark
Mark Henry |
Dec 23 2017, 09:43 AM
Mid engine car I was always told there wasn't much if any advantage. I can see the lighter steering, but wouldn't that be more a low speed advantage? BTW I asked the same thing back in early 2000. got a link to that - might be interesting to review the comments Way back when the club started, maybe even on the bird...haven't got a clue what the thread was called or if I was the OP. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 20th April 2024 - 01:15 AM |
