914-4 Rear Caliper Question |
Tbrown4x4 |
Dec 22 2017, 06:07 AM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Sorry about this, but my Google search didn't get the results I wanted.
I need to go through my rear calipers, but I can't have the car down very long. PMB isn't in the budget. I know the front calipers are different from early to late, but are the rear calipers the same for all the 4's or not? I have a '73 DD, and a '71 parts car, and I was hoping to restore the calipers on the '71 and swap them onto the '73. Is this going to work? Thanks for any advice! Todd |
mlindner |
Dec 22 2017, 06:17 AM
Senior Member Group: Members Posts: 1,521 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Todd, I believe the only difference is top and bottom bleeders on the later model. Check you parts car.....single bleeder. Best, Mark
rgalla9146 |
Dec 22 2017, 06:25 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
YouTube PMB 914 rear caliper DIY
Early and late are functionally identical |
Tbrown4x4 |
Dec 22 2017, 07:32 AM
Great! That will help a lot. Thanks!
mgphoto |
Dec 22 2017, 04:26 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
FYI the '73 has self centering wheels whereas '71 does not.
'71 rear calipers have RIBBE fasteners '73 has standard but very high hardness factor for the size of the bolt. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:17 PM |
