Turn signal lens repair, What's the right glue? |
bbrock |
Dec 24 2017, 12:17 AM
I few months ago, I had several tubs of parts take a spill when an overloaded shelf in the garage collapsed. The worst casualty was one of my Hella rear signal lenses. Luckily, it broke cleanly along the glue line between colors. It should be easy to fix, but I'm not sure what the best glue for the job is. Anyone have advice?
bbrock |
Jan 12 2018, 09:48 PM
I finally got back to this task. I wound up going a different way, sort of. I was hoping for a good solvent fusion bond and assume the lenses are acrylic, or maybe polycarbonate. Either way, the proper weld solvent would be methylene chloride. Turns out that aircraft paint stripper is basically a gel form of methylene chloride. That might be what the 3M adhesive is too. But I had a can of stripper on the shelf and an old and busted up tail light lens to test on. It worked great. Nice, strong, solvent weld. I have my good lens clamped and curing now... and the price was right.
porschetub |
Jan 13 2018, 12:49 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I finally got back to this task. I wound up going a different way, sort of. I was hoping for a good solvent fusion bond and assume the lenses are acrylic, or maybe polycarbonate. Either way, the proper weld solvent would be methylene chloride. Turns out that aircraft paint stripper is basically a gel form of methylene chloride. That might be what the 3M adhesive is too. But I had a can of stripper on the shelf and an old and busted up tail light lens to test on. It worked great. Nice, strong, solvent weld. I have my good lens clamped and curing now... and the price was right. Clean very carefully with a loctite primer then use loctite plastic gell superglue,not the $2 shite,considering the value of the lense don't cheap it ok,you will be good. |
Lo-Fi Version | Time is now: 7th May 2024 - 12:10 AM |
