Turn signal lens repair, What's the right glue? |
bbrock |
Dec 24 2017, 12:17 AM
I few months ago, I had several tubs of parts take a spill when an overloaded shelf in the garage collapsed. The worst casualty was one of my Hella rear signal lenses. Luckily, it broke cleanly along the glue line between colors. It should be easy to fix, but I'm not sure what the best glue for the job is. Anyone have advice?
Mikey914 |
Jan 13 2018, 11:23 AM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
CA is problematic for bonding this type of plastic. It will but the bond is weak. The best way is to dissolve some filings of the plastic with solvent and bond together. You're treating a thermal reaction for a chemical reaction that has limited depth. It is however the best way to glue these together.
Lo-Fi Version | Time is now: 7th May 2024 - 11:19 AM |
