Stock shifter or rennshift? Worth the money? |
Freezin 914 |
Dec 28 2017, 11:14 PM
Senior Member Group: Members Posts: 850 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
I am looking for your opinions, buy a renn shift or keep the stock shifter. Will the rennshift help the ol stick in the mud affect? Also, I do have the factory center console. Any mods needed? (IMG:style_emoticons/default/confused24.gif)
TravisNeff |
Dec 29 2017, 10:33 AM
For a tailshift car, I bet a good inexpensive upgrade would be to get a 915 shifter, put wevo springs in it and be good. If you wanted to go farther you could extend the shifter with a slug and longer tube.
Steve |
Dec 29 2017, 10:43 AM
914 Guru Group: Members Posts: 5,578 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
For a tailshift car, I bet a good inexpensive upgrade would be to get a 915 shifter, put wevo springs in it and be good. If you wanted to go farther you could extend the shifter with a slug and longer tube. Been there.. done that. Wevo and 915 shifter is more expensive than a rennshift. Nothing shifts better than a side shift 914 trans with a Rennshift. |
TravisNeff |
Dec 29 2017, 10:45 AM
For a tailshift car, I bet a good inexpensive upgrade would be to get a 915 shifter, put wevo springs in it and be good. If you wanted to go farther you could extend the shifter with a slug and longer tube. Been there.. done that. Wevo and 915 shifter is more expensive than a rennshift. Nothing shifts better than a side shift 914 trans with a Rennshift. WEVO is nothing but new springs and a new stick, yes? If so, what I said might be good |
Lo-Fi Version | Time is now: 6th May 2024 - 10:41 AM |
