Stock shifter or rennshift? Worth the money? |
Freezin 914 |
Dec 28 2017, 11:14 PM
Senior Member Group: Members Posts: 850 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
I am looking for your opinions, buy a renn shift or keep the stock shifter. Will the rennshift help the ol stick in the mud affect? Also, I do have the factory center console. Any mods needed? (IMG:style_emoticons/default/confused24.gif)
RickS |
Dec 31 2017, 06:30 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
See tons of positive comments but can’t tell if it’s being used on a 4 or a 6. Who is using a Rennshift on a 6 converted with a side shift 901? Does it work for you? Love my teener but shifting has always been its weakest link. Fixing that make the car even better.
Steve |
Dec 31 2017, 07:36 PM
914 Guru Group: Members Posts: 5,578 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
See tons of positive comments but can’t tell if it’s being used on a 4 or a 6. Who is using a Rennshift on a 6 converted with a side shift 901? Does it work for you? Love my teener but shifting has always been its weakest link. Fixing that make the car even better. Same transmission, it doesn’t matter if it’s a 4 or 6 or 8 or Mazda rotary or Subaru The only issue with a six is the shift rod has to be straight or it will hit the motor. I have used my rennshift on a 4 and a six with the same side shift 914 trans. I then converted to a 915 trans. JWest will sell you the parts to convert the 914 side shift rennshift to a 915 rennshift. Pretty simple conversion. |
RickS |
Dec 31 2017, 07:50 PM
See tons of positive comments but can’t tell if it’s being used on a 4 or a 6. Who is using a Rennshift on a 6 converted with a side shift 901? Does it work for you? Love my teener but shifting has always been its weakest link. Fixing that make the car even better. Same transmission, it doesn’t matter if it’s a 4 or 6 or 8 or Mazda rotary or Subaru The only issue with a six is the shift rod has to be straight or it will hit the motor. I have used my rennshift on a 4 and a six with the same side shift 914 trans. I then converted to a 915 trans. JWest will sell you the parts to convert the 914 side shift rennshift to a 915 rennshift. Pretty simple conversion. Can’t find any mention on the JWest site of 915 conversion parts or a kit. I do see the 914 side shift shifter. Do not see a straight shift rod being offered. Hmmm . Still not clear on what the McMark mod is. |
Steve |
Dec 31 2017, 08:02 PM
See tons of positive comments but can’t tell if it’s being used on a 4 or a 6. Who is using a Rennshift on a 6 converted with a side shift 901? Does it work for you? Love my teener but shifting has always been its weakest link. Fixing that make the car even better. Same transmission, it doesn’t matter if it’s a 4 or 6 or 8 or Mazda rotary or Subaru The only issue with a six is the shift rod has to be straight or it will hit the motor. I have used my rennshift on a 4 and a six with the same side shift 914 trans. I then converted to a 915 trans. JWest will sell you the parts to convert the 914 side shift rennshift to a 915 rennshift. Pretty simple conversion. The shift rod has a bend so you are saying it has to be straight and that and the conversion parts are Sold by JWest. Excellent. Will go check the JWest site. Hope that is all the conversion pieces. Still not clear on what the McMark mod is. JWest sells two Rennshift models 914-4 side shift 914-4 tail shift and 915 gear box. I originally had my 914-4 shift rod straightened when I did my six. Later I converted to a PMS shift rod for my six. I don’t think JWest sells six conversion shift rods anymore, but PMS and CFR (Tangerine Racing) does. http://www.patrickmotorsports.com/part/914...smissions-only/ |
Lo-Fi Version | Time is now: 6th May 2024 - 09:31 AM |
