Stock shifter or rennshift? Worth the money? |
Freezin 914 |
Dec 28 2017, 11:14 PM
Senior Member Group: Members Posts: 850 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
I am looking for your opinions, buy a renn shift or keep the stock shifter. Will the rennshift help the ol stick in the mud affect? Also, I do have the factory center console. Any mods needed? (IMG:style_emoticons/default/confused24.gif)
Larmo63 |
Dec 30 2017, 02:46 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I'm not sure I want to sacrifice my hand throttle mechanism.....
I've seen people jury rig them. I'd have to be convinced this is a huge step forward. |
mepstein |
Dec 30 2017, 06:33 PM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
maf914 |
Dec 31 2017, 04:35 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I'm not sure I want to sacrifice my hand throttle mechanism..... I've seen people jury rig them. I'd have to be convinced this is a huge step forward. 914forme modded his rennshift for the hand throttle Here is a link to the thread showing 914forme's Rennshift modification for a hand throttle. See post #213. Here is the photo: http://www.914world.com/bbs2/index.php?sho...9606&st=200 Attached image(s) |
914Toy |
Dec 31 2017, 04:50 PM
Senior Member Group: Members Posts: 717 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
I'm not sure I want to sacrifice my hand throttle mechanism..... I've seen people jury rig them. I'd have to be convinced this is a huge step forward. 914forme modded his rennshift for the hand throttle Here is a link to the thread showing 914forme's Rennshift modification for a hand throttle. See post #213. Here is the photo: That is similar to what I was thinking. Have to look closely at how the space for the throttle handle baseplate is accommodated under the shifter base plate. Also, possibility of mounting the hand throttle assembly say 2' in front of the shifter base plate on the tunnel by drilling holes for bolts and cutting slot for handle and shortening the rod the same amount (?) |
914forme |
Jan 2 2018, 11:48 AM
I'm not sure I want to sacrifice my hand throttle mechanism..... I've seen people jury rig them. I'd have to be convinced this is a huge step forward. 914forme modded his rennshift for the hand throttle Here is a link to the thread showing 914forme's Rennshift modification for a hand throttle. See post #213. Here is the photo: That is similar to what I was thinking. Have to look closely at how the space for the throttle handle baseplate is accommodated under the shifter base plate. Also, possibility of mounting the hand throttle assembly say 2' in front of the shifter base plate on the tunnel by drilling holes for bolts and cutting slot for handle and shortening the rod the same amount (?) To easy to do and no other modifications needed. Also gave me a good reason to make some chips fly. If you don't have access to a mill, it can be done with hand tools. Drill a hole out back big enough for the post to run up through, and then just cut two down the center. It is strong enough that flex should not become an issue with the minimal removal for the handle to move. You also have to drill one hole for the nub oil the hand throttle mount to key into. |
Lo-Fi Version | Time is now: 6th May 2024 - 03:09 PM |
