Racing Wheels?, Been searching, cant find exactly what I need |
stugray |
Dec 29 2017, 02:22 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have a set of steelie racing wheels that are 15 X 7 with a 128mm Backspace (5.0 inch)
Or positive 39mm offset. They look custom made on DOT 15X7 steel hoops. They seem to fit my narrow body car pretty good with Hoosier SM7s. I use a couple if spacers 3/8 or 1/2 but I get no rubbing with rolled fenders. The problem is that I cannot find another set of these wheels for a spare or rain set. Diamond racing makes 15X7 but only up to a 4 inch backspace. Does anyone know where to get some steel 15X7 wheels with 5 inch backspace? Or even hoops that are exactly 15X7? I am about to breakdown and build a rotary table so I can make my own. Desparate Stu |
wndsrfr |
Dec 29 2017, 04:49 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Probably stupid question, would Diamond sell the hoops & centers separately so you could have someone weld them up??
sixnotfour |
Jan 2 2018, 02:46 AM
914 Wizard Group: Members Posts: 10,412 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
i have aluminum 15x7 shells
campbellcj |
Jan 2 2018, 11:28 AM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Sorry I don't know of a source offhand, but curious why you are hunting for steel wheels for racing? Are you talking 4-bolt or 5-bolt?
stugray |
Jan 4 2018, 09:59 PM
Probably stupid question, would Diamond sell the hoops & centers separately so you could have someone weld them up?? I have emails ito diamond with that very question. I also found this source: http://www.millertire.com/products/wheels/...5x-7-rim-blank/ Dont know how that compares to the hoops I have. Edit - I just heard from millertire and they said they do not have VW bolt pattern centers, but they would weld the centers in if I provided them. So - does anyone know where to get VW centers only? I can cut them out of some old wheels but I would rather have new. i have aluminum 15x7 shells Could you elaborate? for sale, needs machining, how many , etc. ? Sorry I don't know of a source offhand, but curious why you are hunting for steel wheels for racing? Are you talking 4-bolt or 5-bolt? I am a 4 bolt car. I havent upgraded to 5 lug. I am also a narrow body with rolled fenders I use a set of the stock Fuchs but the SM7 barely fits on that wheel. So I have a set of steelie 15X7 with 5 inch offset that work perfectly. I just have no spare and would like to not have the fuchs as my backup/rain tire. I bought the set of steelies second hand, so not sure who made them. |
campbellcj |
Jan 5 2018, 10:27 AM
Years ago I had a set of Panasport (Minilite copy) 4-lug wheels that were really nice and IIRC were available in 15x6 and 15x7; the former fit my car OK with 205 DOT-R tires at the time. I did run 195 and 205 -R tires on the stock 4-lug Fuchs also. Can't recall if/how much the fenders were rolled on that car but it had zero flare and a streetable alignment.
sixnotfour |
Jan 6 2018, 02:37 PM
15x7 aluminum are dot approved, I cut the mahles center out and welded the new outer ... they could have had 5 inch BS silver pic,,but the owner wanted the BS as in the blk center pic..
Attached image(s) |
sixnotfour |
Jan 6 2018, 02:41 PM
you could send em to wekdcraft and have add 1,5 to the baxkside, but you willd need spacers to fit..
http://www.weldcraftwheels.com/ |
stugray |
Jan 7 2018, 11:40 PM
15x7 aluminum are dot approved, I cut the mahles center out and welded the new outer ... they could have had 5 inch BS silver pic,,but the owner wanted the BS as in the blk center pic.. Can you make more? Do you cut the centers out yourself? I would imagine you need a big lathe to cut & clean them up |
rhodyguy |
Jan 16 2018, 08:32 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Jeff has LOTS of large equipment.
koozy |
Jan 31 2018, 12:33 AM
Senior Member Group: Members Posts: 646 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
These guys are great. They can do anything you need at a reasonable price
http://www.realwheel.net If you don't see what you want on the website just call and talk to them. Super cool folks and will help in any way they can. Mike |
Lo-Fi Version | Time is now: 28th April 2024 - 06:25 PM |
