subi conversion questions |
hockeymutt |
Dec 31 2017, 11:19 AM
Member Group: Members Posts: 84 Joined: 4-August 08 From: NJ Member No.: 9,388 Region Association: None |
Hey everyone starting to get the pieces for my swap, currently have a WRX engine with complete harness. Picked it up for 1k complete with engine harness and body harness 80k on the motor. here are my questions:
Cooling: MR2 radiator with dual fans in the front? VW reservoir for self bleeding SIDE NOTE: I've been really interested in maybe doing something under the front bumper looks like porsche made a Mid mount radiator but my concern is its way to small (IMG:http://www.914world.com/bbs2/uploads_offsite/cdn4.pelicanparts.com-9388-1514740760.1.jpg) the other option is doing a deck lid mounted set up with 2 porsche mid mount radiators and using push pull flow fans, but can't find anyone that has succeeded with it? Cradle have a few options but leads me to my next question: TRANS: do i keep the stock and use the kenny adapters? about $800-900 or can pick up a forester trans with 160k for $175 plus axle splines, bell crank cables, shifter, pedal assembly with cylinders, 2wd conversion, GPS speedo, plus man hours i'll prob be close to $1500 to convert. my concerns with the subie trans are i would have to go to a floor mounted pedal set up and would have to figure out how to tie into the stock brake system. Think I've figured it out but seems like a lot of work and tweaking to get the bias correct. Resplined axles from dutchman should be easy, Cable bell crank is available online, 2wd is easy to get. thanks for all the help, this will be a long journey but will be worth it. (IMG:style_emoticons/default/headbang.gif) |
hockeymutt |
Jan 2 2018, 06:48 PM
finally was able to complete the wrx engine and harness removal from the donor car. sitting on the cherry picker in my garage. Now time to fix some floor boards. Also have been cut off for this month spending wise, more progress to come. I'll post some pictures.
Also I'll never pull another harness from a suabru in 20 degree weather or at at all. No clue why you would route a harness behind a heater core for 6 inches. Was able to pull the whole thing 98% intact minus airbag wires. Kept the engine relay fuse panel and only cut one connector( think it was a fan relay) . Lessons learned: Bring bolt cutters to cut the harness that goes to the rear. Don't forget the bolt that goes from the support bar to the firewall ( battled the bar for 30 mins before I realized it had to come out) Air bag control box needs to come out Cut connectors to non essential items early (I.e horn wiper motor headlights) the got in the way when routing back into the cabin |
Lo-Fi Version | Time is now: 27th April 2024 - 11:38 AM |
