subi conversion questions |
hockeymutt |
Dec 31 2017, 11:19 AM
Member Group: Members Posts: 84 Joined: 4-August 08 From: NJ Member No.: 9,388 Region Association: None |
Hey everyone starting to get the pieces for my swap, currently have a WRX engine with complete harness. Picked it up for 1k complete with engine harness and body harness 80k on the motor. here are my questions:
Cooling: MR2 radiator with dual fans in the front? VW reservoir for self bleeding SIDE NOTE: I've been really interested in maybe doing something under the front bumper looks like porsche made a Mid mount radiator but my concern is its way to small (IMG:http://www.914world.com/bbs2/uploads_offsite/cdn4.pelicanparts.com-9388-1514740760.1.jpg) the other option is doing a deck lid mounted set up with 2 porsche mid mount radiators and using push pull flow fans, but can't find anyone that has succeeded with it? Cradle have a few options but leads me to my next question: TRANS: do i keep the stock and use the kenny adapters? about $800-900 or can pick up a forester trans with 160k for $175 plus axle splines, bell crank cables, shifter, pedal assembly with cylinders, 2wd conversion, GPS speedo, plus man hours i'll prob be close to $1500 to convert. my concerns with the subie trans are i would have to go to a floor mounted pedal set up and would have to figure out how to tie into the stock brake system. Think I've figured it out but seems like a lot of work and tweaking to get the bias correct. Resplined axles from dutchman should be easy, Cable bell crank is available online, 2wd is easy to get. thanks for all the help, this will be a long journey but will be worth it. (IMG:style_emoticons/default/headbang.gif) |
rnellums |
Jan 2 2018, 04:45 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
If it’s a street car, it’s the 95 degree day in stop and go traffic that would be my concern. Low speed/low load shouldn't be taxing on just about any cooling system provided it's properly bled. High load is where you get into trouble. Have any picture? I'm not sure that this is the Cherokee radiator (I think the cherokee is a bit wider), but you get the idea. Not great for engine access though... |
Rotary'14 |
Jan 12 2018, 07:30 AM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
If it’s a street car, it’s the 95 degree day in stop and go traffic that would be my concern. Low speed/low load shouldn't be taxing on just about any cooling system provided it's properly bled. High load is where you get into trouble. Have any picture? I'm not sure that this is the Cherokee radiator (I think the cherokee is a bit wider), but you get the idea. Not great for engine access though... Actually that's a VW VR6 corrado? radiator. It also does great in stop and go for a rotary which runs hotter than normal piston motors (I bet it can handle a non turbo subie 4 cylinder). The car does run a bit hot on hot days,, but I think this can be resolved with better ducting from underneath as there is none right now. As far as engine access,, I have no problems changing my spark plugs,, and changing belts is still easier than on a type IV. -Robert |
Lo-Fi Version | Time is now: 28th April 2024 - 03:20 AM |
