custom pushrod lengths, head work, cam regrind alter needed lengths |
pgollender |
Dec 31 2017, 11:25 AM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
Happy New Year to the World (914 World) !
(IMG:style_emoticons/default/beerchug.gif) Asking advise from world members about who they have used for custom pushrod lengths. Stock 1.7L motor rebuild. After looking at the VT geometry the ideal length determined to be 272.5mm end-to-end. Would like to go heavy duty aluminum 12mm diameter. Recommendations ? |
mgphoto |
Dec 31 2017, 11:39 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Dominic |
Dec 31 2017, 01:54 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Happy New Year to the World (914 World) ! (IMG:style_emoticons/default/beerchug.gif) Asking advise from world members about who they have used for custom pushrod lengths. Stock 1.7L motor rebuild. After looking at the VT geometry the ideal length determined to be 272.5mm end-to-end. Would like to go heavy duty aluminum 12mm diameter. Recommendations ? Paul, Call CB Performance with your specs and have them cut and assemble them for you for about $100 total for the chrome moly pushrods, set your valve lash at zero and check them again after you break in the engine. Cheers, Dominic |
larryM |
Jan 1 2018, 11:13 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
Smith Bros
https://www.pushrods.net/ i've had 'em make several sets made for other race car projects Asking advise from world members about who they have used for custom pushrod lengths. Recommendations ? |
Olympic 914 |
Jan 2 2018, 07:52 AM
Group: Members Posts: 1,670 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
(IMG:style_emoticons/default/agree.gif) I had them make the pushrods for the teener after I failed at getting the lengths correct cutting the ones that came with the Raby cam kit. I also use their pushrods on one of the Harleys |
Lo-Fi Version | Time is now: 17th May 2024 - 08:21 PM |
