Setting torque on the tranny axle flange, what's the trick??? |
jr91472 |
May 30 2005, 09:21 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
If the tranny is out of the car, how to you torque down the bolt that holds the output flanges (you know, where the CV goes)?
I am getting ready to start open heart surgery on my trans, and plan on replacing all the seals while I am in there. But when you try to torque down on the flange bolt, the opposite flange rotates..... Do you have to put it in gear or something? Must be a trick or I am missing something obvious.... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) thanks in advance. |
SLITS |
May 30 2005, 09:36 AM
Put two bolts in the oppostite flange....put a bar in them that contacts the ground to prevent rotation....put in a gear......torque the other side.
jr91472 |
May 30 2005, 12:03 PM
got it, thanks |
bondo |
May 30 2005, 12:46 PM
Doesn't that only work if you have it bolted to an engine to keep the input shaft from turning? |
jr91472 |
May 31 2005, 10:50 AM
Cap'n Krusty |
May 31 2005, 01:56 PM
Just shove a screwdriver, rod, punch, or long bolt through one of the holes and prop it against a rib on the case. It's under 30 ft/lbs ........................ The Cap'n
JWest |
May 31 2005, 02:34 PM
That's what I do, a long round phillip's screwdriver is what I usually have handy. |
Lo-Fi Version | Time is now: 30th May 2024 - 09:09 AM |
