Six oil level qusetion |
JoeSharp |
May 30 2005, 11:00 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Question, where should the oil level be?
:PERMAGRIN: Joe Attached image(s) |
RAR |
May 30 2005, 11:41 AM
Member Group: Members Posts: 189 Joined: 24-January 04 From: Washington state Member No.: 1,598 |
On the SC's there's a high and low mark, and right in the middle is fine. Any marks on yours?
JoeSharp |
May 30 2005, 11:45 AM
RAR: thanks for the reply. Right now (after all the puking) the level is at the dot in the picture.
Joe |
Aaron Cox |
May 30 2005, 11:46 AM
supposed to check it while running and on a level surface right?
RAR |
May 30 2005, 11:51 AM
Yes, level and running. Let me go look at the marks on mine. |
JoeSharp |
May 30 2005, 11:53 AM
Only one mark on the dip stick. I pulled another one just to compare the tow skicks and aside from rust they are the same.
J P Stein |
May 30 2005, 11:54 AM
Yes, absolutly. I run half way between the marks *hot* & running or it will just pump out the excess. When cold it just barely shows on the stick. |
JoeSharp |
Joe |
JoeSharp |
May 30 2005, 11:59 AM
P.J. It does a good job of pumping it out. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) The ink pen is pointing to the dot that is the only mark I can see on either stick.
Joe |
RAR |
Mine is a straight (flat) rod--no bends except for the finger grip at the top. Low punch mark is 1 1/8" from bottom and high punch mark is 3 5/8" from the bottom. This is a 3.0 litre. Rod part number is 930.107.731.00.
J P Stein |
Don't forget the HOT part.....it makes a surprising difference......bout an inch & a half on my stick. |
RAR |
May 30 2005, 12:04 PM
Yes, also correct. Should be up to normal operating temperature.
JoeSharp |
May 30 2005, 12:06 PM
Oil temp gauge was in the middel of its range.
Joe |
RAR |
May 30 2005, 12:21 PM
The Haynes manual shows a dipstick similar to the ones pictured, but with one less bend in it, so I'm not certain. You might ask in the 911 Pelican Forum, and get someone with the same displacement to answer. My car isn't a 930, but uses a 930 part number. This isn't uncommon, but I'm not certain it's the original dipstick either.
JoeSharp |
May 30 2005, 12:26 PM
I figured that it would seek its own level by puking all over and thats whats happening.
I like the wet look in the engine bay, all nice and shiny, just don't touch anything. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Joe |
RAR |
May 30 2005, 12:30 PM
You could drain some oil out of the tank. A three litre holds about 11 quarts, but initially you put in about 8 and run the engine to suck the oil through it. Doesn't hurt it for brief periods.
ejm |
May 30 2005, 12:45 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The Haynes only shows the /4 but there's a similar manual published by Cypress that covers the six. They show the exact same dipstick, the min mark is the bottom of the stick and max is the mark just above the lower bend.
Lo-Fi Version | Time is now: 19th May 2024 - 09:21 PM |
