Gauging interest Hyd M/C brackets |
dwillouby |
Jan 3 2018, 05:40 PM
Member Group: Members Posts: 391 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Hello,
I am looking at producing some additional Hyd clutch master cyl mounting brackets again. I will have to farm out to a shop to make as I no longer have access to a mill. Bracket will be around $50.00. Trans bracket may be made as well. need final quote from m/s. David |
ablesnead |
Jan 3 2018, 08:19 PM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
I would be interested in the whole kit....bracket (s)...master and slave..
bdstone914 |
Jan 4 2018, 08:09 AM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
[quote name='dwillouby' date='Jan 3 2018, 05:40 PM' post='2564027']
Hello, I am looking at producing some additional Hyd clutch master cyl mounting brackets again. I will have to farm out to a shop to make as I no longer have access to a mill. Bracket will be around $50.00. Trans bracket may be made as well. need final quote from m/s. If you laser cut that bracket it about be about $10. Offering a whole kit made sense. What clutch master does that fit ? What pedal set is used ? Many missing pieces to the puzzle. |
dwillouby |
Jan 4 2018, 08:56 AM
[quote name='bdstone914' date='Jan 4 2018, 07:09 AM' post='2564185']
[quote name='dwillouby' date='Jan 3 2018, 05:40 PM' post='2564027'] Hello, I am looking at producing some additional Hyd clutch master cyl mounting brackets again. I will have to farm out to a shop to make as I no longer have access to a mill. Bracket will be around $50.00. Trans bracket may be made as well. need final quote from m/s. If you laser cut that bracket it about be about $10. Offering a whole kit made sense. What clutch master does that fit ? What pedal set is used ? Many missing pieces to the puzzle. [/quote] If laser cut is acceptable (finish not as nice as machined) cost will come down. I used a pedal set from a 76 for the prototype. This uses the standard Wilwood master cyl. I can supply a list of part numbers / vendors. I cant get a better price on the parts than anyone else. Made and sold several of these in the past with no complaints. David |
ablesnead |
Jan 4 2018, 10:29 AM
part numbers will work for me..I find laser cutting to be excellent
913B |
Jan 4 2018, 10:47 AM
Senior Member Group: Members Posts: 842 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Subscribing to thread. I am interested.
Mueller |
Jan 4 2018, 11:55 AM
David,
Do you have a source for the laser cut parts? If not do you want me to get a quote for you for those being laser cut? I have some parts I drew for someone else that I am sending off for quotes for a local shop to make. No extra charge on my side, just pay for shipping and the parts with no additional mark up. |
euro911 |
Jan 4 2018, 12:44 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
dwillouby |
Jan 8 2018, 03:45 PM
Thanks Mueller for the kind offer but I have a local shop quoting me for laser cutting now.
Also thanks Mark for the endorsement. Should have final quote soon and work out a price for the M/C and slave brackets, slave mounting spacer and hardware ( longer brake m/c bolts and slave mount bolt). Wont get rich from this just fun to do. Thanks David |
shoguneagle |
Jan 12 2018, 08:31 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
I have used the Wilwood master and slave cylinders in making my conversion. Master 3/4 inch diameter; slave 7/8; believe the master cylinder model was the short version to clear the steering and bracing. The kit and mounting looks like my installation which is performing very well. Glad I made the conversion and not looking back
Very good looking kit and brackets. |
dwillouby |
Jan 22 2018, 10:25 AM
Hello,
I finally have some parts available. Set includes; M/C bracket Slave bracket Slave mounting hardware and spacer longer bolts for brake M/C Mounting hardware for clutch M/C Additional parts list. $56.00 shipped USA Thanks David |
913B |
Jan 22 2018, 12:16 PM
To clarify will the additional parts list include :
- Which master and slave to buy ? - Any other items needed (i.e. a hydraulic line from the master to slave) ? What about the how to modification for the clutch pedal to master cylinder ? Thanks Ted |
dwillouby |
Jan 22 2018, 12:58 PM
Yes the list details what parts are required.
I will provide a basic install guide. Thanks David |
913B |
Jan 22 2018, 05:21 PM
Sorry, last question, how much cutting/modification is required ?
Would it be possible to reverse the procedure someday ? (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) Paypal ? Thanks !! (IMG:style_emoticons/default/beerchug.gif) |
dwillouby |
Jan 22 2018, 07:28 PM
You will need to use a 1.5 inch hole saw for m/c access. and drill a small hole to allow a -3 line to pass through.
Paypal works David |
dwillouby |
Jan 24 2018, 08:57 AM
Lo-Fi Version | Time is now: 28th March 2024 - 02:54 PM |
