removing the rear trunk torsion bars, how to COMPLETELY remove them? Update: SUCCESS! |
914 RZ-1 |
Jan 4 2018, 09:50 PM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
EDIT: My last post has my comments on my success.
I've seen the posts about un-attaching the torsion bar on the rear trunk lid when replacing the hinges and such, but how do I take the bars completely off? I want to remove them while the hinges are still good and replace the torsion bars with a gas shock kit. The Haynes manual is not really clear. I do not want to cut the bars, since I'd like to save or possibly sell them. Besides, cutting them sounds dangerous as well. Does the tension get completely released when using the methods in the previous posts about this? I've read them and am still not clear. It seems that these methods are for just taking them partway off to attach new bushings/"ears"/etc. I want to completely remove mine. And I don't want to get whacked! |
bbrock |
Jan 4 2018, 10:32 PM
I took mine off a couple months ago. As I recall, once you disengage them from the hinge rollers, there is still a little tension left, but not much. I was able to unbolt them without getting whacked. I'm a little worried about getting them back on though. But that won't be an issue for you. (IMG:style_emoticons/default/beerchug.gif)
Costa05 |
Jan 4 2018, 11:08 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
I took mine off a couple months ago. As I recall, once you disengage them from the hinge rollers, there is still a little tension left, but not much. I was able to unbolt them without getting whacked. I'm a little worried about getting them back on though. But that won't be an issue for you. (IMG:style_emoticons/default/beerchug.gif) Cut mine into two using a cutoff disc to get them out. Nothing too eventful. |
Steve |
Jan 5 2018, 11:06 AM
914 Guru Group: Members Posts: 5,567 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I just used safety glasses and gloves and removed the bolts / brackets that hold them on. Parts went flying, but no animals were hurt in the process.
rhodyguy |
Jan 5 2018, 11:13 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
First, fully open the trunk and prop it up. Remove rods from rollers. Tightly Pack hand towels on both sides of the cut points on both rods and under/around the rod ends. Have at it with the cutting wheel. Insert potential loud SPRONG sound. When the cut is finished everything happens quickly. Be on high alert.
914 RZ-1 |
Jan 5 2018, 08:08 PM
I don't want to cut them, I want to just remove them. Is there a thread that describes this? Seems like there has to be a way to de-tension them safely. YouTube maybe?
bbrock |
Jan 6 2018, 12:54 AM
I don't want to cut them, I want to just remove them. Is there a thread that describes this? Seems like there has to be a way to de-tension them safely. YouTube maybe? Like I said, I just unbolted them once they were off the hinge rollers and it wasn't a big deal. There is some tension left on them, but not a lot. Most of that will come off as you loosen the brackets. Getting them off was pretty uneventful and no cutting. |
Aidan |
Jan 6 2018, 02:37 AM
Newbie Group: Members Posts: 18 Joined: 26-December 17 From: FWB Member No.: 21,729 Region Association: None |
If Porsche put them in without tension, you can remove them.
defianty |
Jan 6 2018, 03:58 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
I removed mine recently and didn't have any trouble. Once I removed the bars from the hood hinges I just undid the brackets holding them on - very little tension remained.
Can't say I'm looking forward to installing them again with fresh paint everywhere! |
914 RZ-1 |
Jan 15 2018, 11:38 AM
Thought I'd wrap this up for any other newbies that want to do this but are afraid to try:
I removed the hood. Made a tool to grab the torsion bars. I had some 3/16" thick steel bar that I notched and bent as shown elsewhere. I grabbed the bars and moved them off the rollers. Once off, I used my tool to lower them to the car body. The tool came off fairly easy with a slight bang as the tension was released. Not as bad as I thought. I had a friend hold down the brackets with a tube while I loosened the bolts. The only tension remaining was very light; it was enough to slightly bend the bars to go in the brackets, which might have caused them to come off and go flying, but once the screws were off, the brackets actually stayed in place; I had to pry them off with a screwdriver. There appeared to be no torsional tension at all. Much easier than I thought! PS: anybody want to buy some torsion bars? |
Lo-Fi Version | Time is now: 23rd April 2024 - 10:10 AM |
