FS 911 Engine Case - UPDATED, 7R Case, Crank, Rods, Oil Pump |
infraredcalvin |
Jan 7 2018, 12:13 AM
Distracted Member Group: Members Posts: 1,504 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
UPDATED: 1/7/18
What you see is what you get, 911/92 7R case & used main bearings $400 +shipping & PP fees $1,000 + Ship OBO While collecting parts for my build I ended up with one too many engine cases, so I’m letting this one go. I bought this case from a well-known seller on the bird board. I don’t know much about this case except that it has been worked on previously and what the previous seller disclosed. It has a couple heli-coils (one removed by me), the remaining look to be time certs. Some are backing out, they could be reseated with the proper insert tool, or I had planned to remove all and replace with case savers (which seems to be the recommendation with these cases). There were a few items that were not disclosed to me that I’d like to make sure I get out there: There is a chunk taken out where the oil cooler mounts – as seen in the pictures. In no way does this interfere with the sealing or mounting of the oil cooler it’s just cosmetic (I just wanted to disclose as it was a surprise to me). All in all it’s a good case that has had some work done, and as with all mag cases needs a bit more. Not included are head studs, a couple were broken or corroded, case bolts/nuts were removed and not provided by previous seller. Thanks for looking, pics to follow, Pat |
infraredcalvin |
Jan 7 2018, 12:18 AM
Attached thumbnail(s) |
infraredcalvin |
Jan 7 2018, 12:21 AM
infraredcalvin |
Jan 7 2018, 12:24 AM
infraredcalvin |
Jan 7 2018, 12:29 AM
infraredcalvin |
Jan 7 2018, 12:32 AM
gcrotvik |
Jan 7 2018, 12:38 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
PM sent.
infraredcalvin |
Jan 7 2018, 02:18 PM
Case and used bearings only available for $400 +ship and pp fees. I’ll update the above later.
Crank, rods, intermediate shaft and pump SOLD. Thank you 914World & Greg for keeping my build going! |
pete-stevers |
Jan 9 2018, 11:28 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
I pm'd you on the case...
I will take it if it is a 2.4 7r case Thanks Text is best |
infraredcalvin |
Jan 15 2018, 11:58 AM
Bump, 7R Case (2.7) still available. Will be posting on the bird at higher price shortly.
infraredcalvin |
Jan 21 2018, 10:09 PM
BUMP
infraredcalvin |
Jan 26 2018, 12:49 AM
Bump
infraredcalvin |
Mar 26 2018, 03:56 PM
BUMP - Posting on the bird site with increased pricing, 914 members will get pricing shown here...
Optimusglen |
Mar 28 2018, 12:27 PM
Senior Member Group: Members Posts: 901 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
I'm not up to date on case prices, but that seems super inexpensive. Even noting that it'll need some work.
JmuRiz |
Mar 28 2018, 01:10 PM
914 Guru Group: Members Posts: 5,421 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Looks better than the 7R case I sent off to get work done on. |
Lo-Fi Version | Time is now: 19th April 2024 - 05:06 AM |
