55w driving lights on a 35w circuit |
72 IXXIV |
Jan 7 2018, 11:23 AM
Member Group: Members Posts: 62 Joined: 1-January 15 From: San Francisco Member No.: 18,277 Region Association: Northern California |
I’m considering replacing my stock 35w fog lights with a couple h3 55w halogens as has been described on the forum. Is that too much load for the wiring, or is it within the margin of error?
windforfun |
Jan 7 2018, 07:01 PM
Senior Member Group: Members Posts: 1,780 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
1 watt = 1 volt amp. Your current will therefore increase by 57 %. The fuse will probably blow before the wiring is damaged. The fuses are supposed to protect the wiring & not the loads. Don't use a larger fuse until you run a heavier gauge wire. This assumes that the fog lights are on their own circuit with its own fuse.
Lo-Fi Version | Time is now: 14th May 2024 - 05:17 AM |
