Subaru swapped fuel mileage, What engines are you guys running and what kind of mileage? |
749142 |
Jan 8 2018, 08:13 AM
Member Group: Members Posts: 254 Joined: 8-January 08 From: Bakersfield, Ca Member No.: 8,545 |
Been a while since I’ve been in here. Had the 914 running with a turbocharged ej20. Ended up blowing that motor. Considering different engine options. Naturally aspirated ej20-25, or back with a turbo ej20, EZ30 or eg33 and I’m wondering what you subie guys are getting as far as fuel economy. I live in central Ca and my father lives in Arizona. My wrx is a little expensive at 25mpg or less to go see him. Thinking of turning the 914 into more of a fuel economy road trip car. Mind you I still want some power. So what are you guys gettin?
76-914 |
Jan 8 2018, 12:18 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,483 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
EZ30D, 25mpg
A&P Mech |
Jan 8 2018, 01:46 PM
Member Group: Members Posts: 400 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
I honestly couldn't tell you what my ez30 gets. Every time I get in my 914 my IQ drops at least 100 points ( putting me in negative numbers (IMG:style_emoticons/default/drooley.gif) ) and I drive it like I stole it. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/happy11.gif)
burton73 |
Jan 8 2018, 02:16 PM
burton73 Group: Members Posts: 3,484 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
When you make power you are using fuel. My 2015 Corvette got 50 Miles on the Frey when you eased it at 60 but when you made 460HP it went through the fuel.
Boost is more fuel going into Eng. making a 3-liter a 4.5-liter is a sense. Most people do not care what the fuel is costing when they are buying a thrill. Bob B |
Mueller |
Jan 8 2018, 02:36 PM
I talked to a member here that has a 3.5 liter Honda/Acura V6 in his 914 that is getting 30 on the freeway. Well over 250hp as well. Tempting
Chris914n6 |
Jan 8 2018, 03:43 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
24 city, 29 hwy @ 90 with a 3.0L
The new 3.5L should be the same as it's really a factor of weight, aerodynamics and driving style. |
Mark Henry |
Jan 8 2018, 05:09 PM
I honestly couldn't tell you what my ez30 gets. Every time I get in my 914 my IQ drops at least 100 points ( putting me in negative numbers (IMG:style_emoticons/default/drooley.gif) ) and I drive it like I stole it. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/happy11.gif) This is number 1 (IMG:style_emoticons/default/first.gif) I have 2.6 liter T4 in my 1700lb bug, very hi performance but FI so my thought was it should get somewhat decent mileage. Nope... it slurps down gas like an alcoholic at a free bar. With a 10 gallon tank pumping gas almost every time I drove it gets old. Last summer I did a grand experiment for a couple weeks, I drove it like a standard stock bug, like granny going to pick up her groceries. I stopped spirited take offs, drove much closer to the speed limit, right hand lane, stayed behind trucks and Harley's instead of passing them....in other words had no fun. You guessed it, I was averaging over 30mpg. woo-hoo (IMG:style_emoticons/default/yellowsleep[1].gif) But what the fuch is the fun in that! Yep my mileage sucks again! (IMG:style_emoticons/default/dry.gif) At least I have a smile on my face...except at the gas station. (IMG:style_emoticons/default/rolleyes.gif) Now I have my 3.0 high performance weber /6 in my 914...not even going to look at my gas bills. |
Aircooledfool |
Jan 8 2018, 05:25 PM
Member Group: Members Posts: 106 Joined: 17-September 06 From: Texas Member No.: 6,858 Region Association: None |
Can I hijack this thread with a question to you that are running the EZ30D, what are you using for fuel management? Can you run the stock Subaru system?
hockeymutt |
Jan 8 2018, 05:33 PM
Member Group: Members Posts: 84 Joined: 4-August 08 From: NJ Member No.: 9,388 Region Association: None |
Can I hijack this thread with a question to you that are running the EZ30D, what are you using for fuel management? Can you run the stock Subaru system? The cheapest route would be to get the harness and ecu from a donor and send it off to get converted to vw/Porsche ($600) Or megaaquirt or stinger which is around 1200 from what I've found. |
Aircooledfool |
Jan 8 2018, 05:41 PM
Can I hijack this thread with a question to you that are running the EZ30D, what are you using for fuel management? Can you run the stock Subaru system? The cheapest route would be to get the harness and ecu from a donor and send it off to get converted to vw/Porsche ($600) Or megaaquirt or stinger which is around 1200 from what I've found. Who does the harness conversion? That sounds like the best option for a daily driver. I'm in the early planning stages for a EZ30D daily driver. Thanks for your input! |
hockeymutt |
Jan 8 2018, 06:04 PM
Can I hijack this thread with a question to you that are running the EZ30D, what are you using for fuel management? Can you run the stock Subaru system? The cheapest route would be to get the harness and ecu from a donor and send it off to get converted to vw/Porsche ($600) Or megaaquirt or stinger which is around 1200 from what I've found. Who does the harness conversion? That sounds like the best option for a daily driver. I'm in the early planning stages for a EZ30D daily driver. Thanks for your input! There's a few people on line, I'll be going with autoventure since he's afforadable and does a really good job |
76-914 |
Jan 9 2018, 11:37 AM
I checked out his website and did not see where he offers a harness for the EZ30D series. Maybe he does but does not list it. (IMG:style_emoticons/default/confused24.gif)
rnellums |
Jan 9 2018, 08:53 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I've touched 40 a few times cruising at altitude in my EZ30D. And as for harnesses, make your own! All the literature is out there and quite a few have gone through it! Then you'll know how to troubleshoot if anything goes wrong!
Aircooledfool |
Jan 10 2018, 10:38 AM
I contacted John at AutoVenture and he said he can make the harness for the EZ30D. We didn't nailed down pricing since it will vary depending on what transmission and EMS is used. John mentioned that someone who is using the stock Subaru ECM had some issues with idle. What would be ideal would be for several of us that are planning the same conversion could work together on design and wiring harness. I'm guessing that some sort of group buy might be possible. My goals are for a reliable daily driver using the EZ30D, Subaru transmission, and Subaru ECM if it can be confirmed as a reliable option.
Chris914n6 |
Jan 10 2018, 03:02 PM
I just used my stock harness. The trick is getting all the power wires connected and on the right circuit (battery & switched). Just need to read the wiring diagram thoroughly.
I may strip the unused plugs out someday but it's really not that important. |
76-914 |
Jan 10 2018, 05:26 PM
Can I hijack this thread with a question to you that are running the EZ30D, what are you using for fuel management? Can you run the stock Subaru system? The cheapest route would be to get the harness and ecu from a donor and send it off to get converted to vw/Porsche ($600) Or megaaquirt or stinger which is around 1200 from what I've found. Who does the harness conversion? That sounds like the best option for a daily driver. I'm in the early planning stages for a EZ30D daily driver. Thanks for your input! I've got 11,000 on mine. Only problem was a self induced cooling issue. Runs perfectly every time I take it out. (IMG:style_emoticons/default/beerchug.gif) |
749142 |
Jan 12 2018, 08:07 AM
I imagine 25mpg with an EZ30 should be able to beaten with some better gearing for the Highway gearing. Seeing how that engine has an 80mm stroke. It should have plenty of torque below 2600 to pull a 914 at freeway speeds. I’d honestly like to see 2400rpm at 75. Spinning all that mass up with that longer stroke seems like a waste of fuel.
What transmissions are you guys running? |
rnellums |
Jan 12 2018, 10:09 PM
I contacted John at AutoVenture and he said he can make the harness for the EZ30D. We didn't nailed down pricing since it will vary depending on what transmission and EMS is used. John mentioned that someone who is using the stock Subaru ECM had some issues with idle. What would be ideal would be for several of us that are planning the same conversion could work together on design and wiring harness. I'm guessing that some sort of group buy might be possible. My goals are for a reliable daily driver using the EZ30D, Subaru transmission, and Subaru ECM if it can be confirmed as a reliable option. I have a complete ECU Pinout and power wiring distribution diagram (including relays and fusing) for a stock 2001 EZ30 that I can share. 2002, 2003 ECUs are very similar, but some colors/pins shifted on the ECU connectors (engine connectors are identical) and will require some more diligence. All you need to provide is Gnd, +12 Batt, and switched +12. then pull signals out for gauges. Even runs OBD readers! I've recorded almost 40 mpg in my EZ30 with an 02 WRX 5mt. |
749142 |
Jan 15 2018, 05:29 PM
I contacted John at AutoVenture and he said he can make the harness for the EZ30D. We didn't nailed down pricing since it will vary depending on what transmission and EMS is used. John mentioned that someone who is using the stock Subaru ECM had some issues with idle. What would be ideal would be for several of us that are planning the same conversion could work together on design and wiring harness. I'm guessing that some sort of group buy might be possible. My goals are for a reliable daily driver using the EZ30D, Subaru transmission, and Subaru ECM if it can be confirmed as a reliable option. I have a complete ECU Pinout and power wiring distribution diagram (including relays and fusing) for a stock 2001 EZ30 that I can share. 2002, 2003 ECUs are very similar, but some colors/pins shifted on the ECU connectors (engine connectors are identical) and will require some more diligence. All you need to provide is Gnd, +12 Batt, and switched +12. then pull signals out for gauges. Even runs OBD readers! I've recorded almost 40 mpg in my EZ30 with an 02 WRX 5mt. I’d like to get a copy of that pinout if/when I start this conversion. I’m about 80% sure I’m going to use the EZ30. What are you’re freeway rpms with the 02 wrx transmission? |
rnellums |
Jan 15 2018, 07:31 PM
I contacted John at AutoVenture and he said he can make the harness for the EZ30D. We didn't nailed down pricing since it will vary depending on what transmission and EMS is used. John mentioned that someone who is using the stock Subaru ECM had some issues with idle. What would be ideal would be for several of us that are planning the same conversion could work together on design and wiring harness. I'm guessing that some sort of group buy might be possible. My goals are for a reliable daily driver using the EZ30D, Subaru transmission, and Subaru ECM if it can be confirmed as a reliable option. I have a complete ECU Pinout and power wiring distribution diagram (including relays and fusing) for a stock 2001 EZ30 that I can share. 2002, 2003 ECUs are very similar, but some colors/pins shifted on the ECU connectors (engine connectors are identical) and will require some more diligence. All you need to provide is Gnd, +12 Batt, and switched +12. then pull signals out for gauges. Even runs OBD readers! I've recorded almost 40 mpg in my EZ30 with an 02 WRX 5mt. I’d like to get a copy of that pinout if/when I start this conversion. I’m about 80% sure I’m going to use the EZ30. What are you’re freeway rpms with the 02 wrx transmission? Still higher than I would like, 3700 or so at 75 I think |
Lo-Fi Version | Time is now: 18th April 2024 - 10:24 PM |
