Subaru swapped fuel mileage, What engines are you guys running and what kind of mileage? |
749142 |
Jan 8 2018, 08:13 AM
Member Group: Members Posts: 254 Joined: 8-January 08 From: Bakersfield, Ca Member No.: 8,545 |
Been a while since I’ve been in here. Had the 914 running with a turbocharged ej20. Ended up blowing that motor. Considering different engine options. Naturally aspirated ej20-25, or back with a turbo ej20, EZ30 or eg33 and I’m wondering what you subie guys are getting as far as fuel economy. I live in central Ca and my father lives in Arizona. My wrx is a little expensive at 25mpg or less to go see him. Thinking of turning the 914 into more of a fuel economy road trip car. Mind you I still want some power. So what are you guys gettin?
Aircooledfool |
Jan 10 2018, 10:38 AM
Member Group: Members Posts: 106 Joined: 17-September 06 From: Texas Member No.: 6,858 Region Association: None |
I contacted John at AutoVenture and he said he can make the harness for the EZ30D. We didn't nailed down pricing since it will vary depending on what transmission and EMS is used. John mentioned that someone who is using the stock Subaru ECM had some issues with idle. What would be ideal would be for several of us that are planning the same conversion could work together on design and wiring harness. I'm guessing that some sort of group buy might be possible. My goals are for a reliable daily driver using the EZ30D, Subaru transmission, and Subaru ECM if it can be confirmed as a reliable option.
Lo-Fi Version | Time is now: 27th April 2024 - 11:41 AM |
