FS: 1972, Tangerine 1.7L D-Jet Complete (Mostly), Disassembled / Not parting out / Oklahoma City |
pcar916 |
Jan 8 2018, 01:52 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Hi Folks,
This is a mostly complete Oklahoma City 1.7L car with full-length replacement longitudinal pieces included. $1000 and come pick it up. There is a slideshow at… http://s346.photobucket.com/user/inv4me/slideshow/?sort=2 Sold as-is PM with questions. Phone number on demand. Thanks, Ron Notes: 1. Missing parts might still be discovered, we're still combing the warehouse for them. 2. This engine has a replacement case and no serial number on either of the normal places. It has a 2.0L induction system, but the stroke has not been established. So… not sure which displacement it is. Description: A. Front of car Gas and vent tanks Hood with Wipers Side marker lights Parking light buckets and lenses Wiper assembly Eyelids Headlight assemblies Headlight sheet metal covers Headlight valences Heat / defrost / fan ventilation stuff (front trunk) Front trunk board (carpeted… above spare tire/AC condenser) plywood is warped Missing Windshield (original was cracked) Fuel tank fitting Steering column bracket Front sway bar B. Middle of car Full-length longitudinal-stiffeners for rusted out longitudinals Likely a 1.7L or 2.0L Engine (See note above) Tail-shifter transaxle Doors (early) Shifter w/ linkages Idle lever Heater flapper boxes Smoothed top w/ both front clamps and 1 rear clamp Seats (upholstery is rough) Center console w/padded top Interior sail panel pad Sunshades Top dash pad (cracked) Lower dash pad with vents Ign. switch Turn signal / wiper switch assembly (on column) Speedo cable Peddle cluster Door sill covers / hardware (less screws) Trunk hinges and release mechanisms Exhaust hanger Engine compartment relay panel cover Rocker panel covers (both) C: Known missing items Glove box & glove-box door Steering column bracket Seat belts Taillight lenses |
pcar916 |
Jan 9 2018, 01:56 PM
Price drop from $4000 to $1000. This one is in the way!
Lo-Fi Version | Time is now: 18th April 2024 - 02:06 AM |
