Look like the right list of bits for a 914/6 build |
Tdskip |
Jan 11 2018, 11:25 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning, can we pretend for a minute that I was going to do a 914/6 build with a 1974 that is already missing its engine. Further, can we imagine that I would be trying to build a car that would be used rather than showed, and that building a clone and/or a "correct" car is not a goal. The goal would be a well balanced, reliable and sorted out car for backroad touring use.
Does this look like the necessary bits? -2.7 or 3.0l engine with CIS (have this) -engine tin -oil tank -front oil cooler -to/from oil cooler lines -throttle linkage -fuel pump -fuel lines -engine lid latch relocation bits (due to CIS) -headers -flywheel -ECU -CDI box -O2 sensor -Engine mount -320i front brakes since the extra horsepower probably deserves it Edit - adding these from Cario and Defianty muffler thermostat for the oil cooler gauges to work with new engine Filler neck for the oil tank Oil dipstick Oil filter console Six muffler 19mm master cylinder FI harness (missed that one) Edit - adding from Lucky9146 Conversion Wiring harness? 914-6 trans mid-plate for throttle or some other contraption, not sure w/FI Shift Rod modified for headers Oil cooler thermostat Oil cooler shroud Oil Cooler Fans Oil Fed chain tensioners Edit - adding from mb911 headers or heat exchangers Am I missing anything? I did try searching and reading prior discussions. Thanks! |
defianty |
Jan 11 2018, 11:36 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
Yep that's a good list to start, here's a few extra bits you'll need.
Filler neck for the oil tank Oil dipstick Oil filter console Six muffler 19mm master cylinder |
Tdskip |
Jan 11 2018, 11:48 AM
Thanks gentlemen.
@Cario, thanks for pointing out the body stiffening. I didn't list that since I had already decided to do it, it has become a SOP on all the builds. I just finished doing that on my 912 project actually. Thanks for that and the other bits. @defianty, thanks for the response as well and those other bits I missed. The plan would be to take my time, do what Cario confirmed related to shell stiffening and assemble all of the bits. I have other things to keep me busy so I have the "luxury" of not having to rush. Make sense? Lots of coaching and experiences in past threads that have been a huge help. |
Lo-Fi Version | Time is now: 24th April 2024 - 05:03 PM |
