Look like the right list of bits for a 914/6 build |
Tdskip |
Jan 11 2018, 11:25 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning, can we pretend for a minute that I was going to do a 914/6 build with a 1974 that is already missing its engine. Further, can we imagine that I would be trying to build a car that would be used rather than showed, and that building a clone and/or a "correct" car is not a goal. The goal would be a well balanced, reliable and sorted out car for backroad touring use.
Does this look like the necessary bits? -2.7 or 3.0l engine with CIS (have this) -engine tin -oil tank -front oil cooler -to/from oil cooler lines -throttle linkage -fuel pump -fuel lines -engine lid latch relocation bits (due to CIS) -headers -flywheel -ECU -CDI box -O2 sensor -Engine mount -320i front brakes since the extra horsepower probably deserves it Edit - adding these from Cario and Defianty muffler thermostat for the oil cooler gauges to work with new engine Filler neck for the oil tank Oil dipstick Oil filter console Six muffler 19mm master cylinder FI harness (missed that one) Edit - adding from Lucky9146 Conversion Wiring harness? 914-6 trans mid-plate for throttle or some other contraption, not sure w/FI Shift Rod modified for headers Oil cooler thermostat Oil cooler shroud Oil Cooler Fans Oil Fed chain tensioners Edit - adding from mb911 headers or heat exchangers Am I missing anything? I did try searching and reading prior discussions. Thanks! |
Tdskip |
Jan 12 2018, 10:14 PM
OK - to try and get myself organized and start hunting for parts at best possible prices (while supporting members here when/where possible) I have taken the list you helped me prepare and started listing the parts source next to the item needed.
Needed item | Sourcing -engine tin | Fiberglass OK to use? -oil tank | going with Ben's -front oil cooler | any recommendations? -to/from oil cooler lines | going with Ben'sn -throttle linkage | any recommendations? -fuel pump | 3.0 911 pump OK I assume? -fuel lines | custom, or is there a kit? -engine lid latch relocation bits (due to CIS) | home fabricate? -flywheel | lighten the 3.0 one or leave as is? -CDI box | got it covered -O2 sensor | not needed -Engine mount | firewall mount best? -muffler | got it -thermostat for the oil cooler | got it -gauges to work with new engine | 3.0 911 tachometer ordered, what other gauges -Filler neck for the oil tank | Ben? -Oil dipstick | Ben? -Oil filter console | Ben? -19mm master cylinder| | got it covered -FI harness | Perry Kiehl -Conversion Wiring harness? | any ideas? -914-6 trans mid-plate for throttle or some other contraption, not sure w/FI | any ideas? -Shift Rod modified for headers | Tangerine -Oil Cooler Fans | got it covered -Oil Fed chain tensioners | got it covered -headers or heat exchangers | got it covered Any input? |
Lo-Fi Version | Time is now: 24th April 2024 - 02:59 PM |
