Look like the right list of bits for a 914/6 build |
Tdskip |
Jan 11 2018, 11:25 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning, can we pretend for a minute that I was going to do a 914/6 build with a 1974 that is already missing its engine. Further, can we imagine that I would be trying to build a car that would be used rather than showed, and that building a clone and/or a "correct" car is not a goal. The goal would be a well balanced, reliable and sorted out car for backroad touring use.
Does this look like the necessary bits? -2.7 or 3.0l engine with CIS (have this) -engine tin -oil tank -front oil cooler -to/from oil cooler lines -throttle linkage -fuel pump -fuel lines -engine lid latch relocation bits (due to CIS) -headers -flywheel -ECU -CDI box -O2 sensor -Engine mount -320i front brakes since the extra horsepower probably deserves it Edit - adding these from Cario and Defianty muffler thermostat for the oil cooler gauges to work with new engine Filler neck for the oil tank Oil dipstick Oil filter console Six muffler 19mm master cylinder FI harness (missed that one) Edit - adding from Lucky9146 Conversion Wiring harness? 914-6 trans mid-plate for throttle or some other contraption, not sure w/FI Shift Rod modified for headers Oil cooler thermostat Oil cooler shroud Oil Cooler Fans Oil Fed chain tensioners Edit - adding from mb911 headers or heat exchangers Am I missing anything? I did try searching and reading prior discussions. Thanks! |
Tdskip |
Mar 8 2018, 05:09 PM
OK - time for an update here.
I've decided to run 3.2 so that changes some things. One open item is where to source the bellhousing mounted throttle cable assembly. Stock clutch cable is OK, right? |
mepstein |
Mar 8 2018, 05:53 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
OK - time for an update here. I've decided to run 3.2 so that changes some things. One open item is where to source the bellhousing mounted throttle cable assembly. Stock clutch cable is OK, right? I’m using the stock clutch cable. Contact Rich - A914guy@aol.com He is the guy who makes the throttle bellcrank with an adaptor to bolt onto your stock 914 trans. He includes the 914-6 cable and correct shaft to connect the bellcrank to the throttle plate. You either need to modify the small ball connector on the throttle plate arm to the other side of the arm (my guy did it in 5 minutes) or buy a kit to do it from Sierra Madre. It’s a very easy mod but easier when the engine is out of the car. |
Tdskip |
Mar 8 2018, 06:42 PM
OK - time for an update here. I've decided to run 3.2 so that changes some things. One open item is where to source the bellhousing mounted throttle cable assembly. Stock clutch cable is OK, right? I’m using the stock clutch cable. Contact Rich - A914guy@aol.com He is the guy who makes the throttle bellcrank with an adaptor to bolt onto your stock 914 trans. He includes the 914-6 cable and correct shaft to connect the bellcrank to the throttle plate. You either need to modify the small ball connector on the throttle plate arm to the other side of the arm (my guy did it in 5 minutes) or buy a kit to do it from Sierra Madre. It’s a very easy mod but easier when the engine is out of the car. Thank you, I just emailed Rich. Ben, let's get the oil tank sorted out first before you spend anymore of my money! |
mb911 |
Mar 9 2018, 06:11 AM
914 Guru Group: Members Posts: 6,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
OK - time for an update here. I've decided to run 3.2 so that changes some things. One open item is where to source the bellhousing mounted throttle cable assembly. Stock clutch cable is OK, right? I’m using the stock clutch cable. Contact Rich - A914guy@aol.com He is the guy who makes the throttle bellcrank with an adaptor to bolt onto your stock 914 trans. He includes the 914-6 cable and correct shaft to connect the bellcrank to the throttle plate. You either need to modify the small ball connector on the throttle plate arm to the other side of the arm (my guy did it in 5 minutes) or buy a kit to do it from Sierra Madre. It’s a very easy mod but easier when the engine is out of the car. Thank you, I just emailed Rich. Ben, let's get the oil tank sorted out first before you spend anymore of my money! When ever your ready. Let me know when you want to place the order. |
Lo-Fi Version | Time is now: 25th April 2024 - 07:35 PM |
