Look like the right list of bits for a 914/6 build |
Tdskip |
Jan 11 2018, 11:25 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning, can we pretend for a minute that I was going to do a 914/6 build with a 1974 that is already missing its engine. Further, can we imagine that I would be trying to build a car that would be used rather than showed, and that building a clone and/or a "correct" car is not a goal. The goal would be a well balanced, reliable and sorted out car for backroad touring use.
Does this look like the necessary bits? -2.7 or 3.0l engine with CIS (have this) -engine tin -oil tank -front oil cooler -to/from oil cooler lines -throttle linkage -fuel pump -fuel lines -engine lid latch relocation bits (due to CIS) -headers -flywheel -ECU -CDI box -O2 sensor -Engine mount -320i front brakes since the extra horsepower probably deserves it Edit - adding these from Cario and Defianty muffler thermostat for the oil cooler gauges to work with new engine Filler neck for the oil tank Oil dipstick Oil filter console Six muffler 19mm master cylinder FI harness (missed that one) Edit - adding from Lucky9146 Conversion Wiring harness? 914-6 trans mid-plate for throttle or some other contraption, not sure w/FI Shift Rod modified for headers Oil cooler thermostat Oil cooler shroud Oil Cooler Fans Oil Fed chain tensioners Edit - adding from mb911 headers or heat exchangers Am I missing anything? I did try searching and reading prior discussions. Thanks! |
mepstein |
Mar 8 2018, 07:05 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You don’t need a custom engine harnes with a 3.2, you can buy the PMS harness adaptor. ~$180. It allows you to just plug the engine to the chassis harness.
Read this classic thread on upgrading your drivetrain. You will need bigger cv’s for these bigger engines. http://www.914world.com/bbs2/index.php?showtopic=91963 |
Tdskip |
Mar 9 2018, 10:13 AM
You don’t need a custom engine harnes with a 3.2, you can buy the PMS harness adaptor. ~$180. It allows you to just plug the engine to the chassis harness. Read this classic thread on upgrading your drivetrain. You will need bigger cv’s for these bigger engines. http://www.914world.com/bbs2/index.php?showtopic=91963 Thanks, I goofed on my update in that were redundant items for the harness, I did list the PMS adapter after we spoke. (Thanks) What is the scoop on the axles? Is there a go to part? 911 bits? None of this is theoretical anymore-I dropped the engine off at the shop yesterday. Gulp. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 26th April 2024 - 10:44 AM |
