> Walbro Fuel Pump Location - Subaru Conversion, Engine Compartment or Under Fuel Tank
Costa05
post Jan 11 2018, 10:39 PM
Wanting to locate my Walbro high pressure fuel pump in engine compartment for service reasons (low on firewall). Vendor suggests 6" from fuel tank for best performance. Anyone have experience with engine compartment location on similar conversion? Bad idea? Thanks in advance.
Rich
post Jan 12 2018, 04:20 PM
Repeat Offender
See post #765 on the last page http://www.914world.com/bbs2/index.php?sho...1776&st=760
914forme
post Jan 12 2018, 04:31 PM
Under the tank, I normally mount mine under on the front suspension cross bar, under the rack and pinion. On the steel stuff, I just weld a few nuts on and build a mount for the pump, you can use isolators mounts to keep the buzzing down.
I am wondering why not in the tank. Here is what I did with part numbers etc....
Costa05
post Jan 12 2018, 08:38 PM
QUOTE(76-914 @ Jan 12 2018, 05:20 PM) *
Your frunk setup could be a good option for me. Lot of stuff going on up there but the pump is pretty small. Filter is right there too.
Good suggestion. Anyone else try engine compartment yet with results?
tazz9924
post Jan 12 2018, 09:08 PM
Mine is in the engine bay, no problems to report.
Chris914n6
post Jan 12 2018, 09:14 PM
It's a fighter not a runner.
You should be fine at the stock location, as the Subie won't be blowing hot air everywhere. At least until the 40 year old plastic fuel lines in the center tunnel get replaced.
tazz9924
post Jan 12 2018, 11:19 PM
QUOTE(Chris914n6 @ Jan 12 2018, 07:14 PM) *
Agreed, please replace those plastic fuel lines
Costa05
post Jan 13 2018, 07:08 PM
QUOTE(tazz9924 @ Jan 13 2018, 12:19 AM) *
Yep got the old plastic ones out already. Thinking I might try the engine bay location for the pump. Stubborn at following rules.
Thanks guys.
- Lo-Fi Version Time is now: 24th April 2018 - 02:46 PM
