Walbro Fuel Pump Location - Subaru Conversion, Engine Compartment or Under Fuel Tank |
Costa05 |
Jan 11 2018, 10:39 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Wanting to locate my Walbro high pressure fuel pump in engine compartment for service reasons (low on firewall). Vendor suggests 6" from fuel tank for best performance. Anyone have experience with engine compartment location on similar conversion? Bad idea? Thanks in advance.
Rich |
76-914 |
Jan 12 2018, 04:20 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,490 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
See post #765 on the last page http://www.914world.com/bbs2/index.php?sho...1776&st=760
914forme |
Jan 12 2018, 04:31 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Under the tank, I normally mount mine under on the front suspension cross bar, under the rack and pinion. On the steel stuff, I just weld a few nuts on and build a mount for the pump, you can use isolators mounts to keep the buzzing down.
I am wondering why not in the tank. Here is what I did with part numbers etc.... |
Costa05 |
Jan 12 2018, 08:38 PM
Your frunk setup could be a good option for me. Lot of stuff going on up there but the pump is pretty small. Filter is right there too. Good suggestion. Anyone else try engine compartment yet with results? |
tazz9924 |
Jan 12 2018, 09:08 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Mine is in the engine bay, no problems to report.
Chris914n6 |
Jan 12 2018, 09:14 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You should be fine at the stock location, as the Subie won't be blowing hot air everywhere. At least until the 40 year old plastic fuel lines in the center tunnel get replaced.
tazz9924 |
Jan 12 2018, 11:19 PM
Costa05 |
Jan 13 2018, 07:08 PM
You should be fine at the stock location, as the Subie won't be blowing hot air everywhere. At least until the 40 year old plastic fuel lines in the center tunnel get replaced. Agreed, please replace those plastic fuel lines Yep got the old plastic ones out already. Thinking I might try the engine bay location for the pump. Stubborn at following rules. Thanks guys. |
Lo-Fi Version | Time is now: 25th April 2024 - 10:58 PM |
