Headlight question |
cedric9146 |
Jan 12 2018, 01:59 AM
Newbie Group: Members Posts: 18 Joined: 19-September 12 From: Belgium Member No.: 14,948 Region Association: Europe |
Hi guys, need your help !
I'm not a mechanic at all, but want to fix my car myself for once ! (IMG:style_emoticons/default/biggrin.gif) Driver side High beam is not working. All rest is fine. What could it be? (IMG:style_emoticons/default/confused24.gif) They are sealed beam lamps, so i presume the high and normal driving bulbs are inside, and you can not open it? So need to replace it with a complete new light? Fuses are ok. Removed the plastic cover and chrome ring. There is only one big plug connected. What is the small white wire for? I have read about replacing them by H4's . Is this just plug and play? Thanks for the help ! Cedric Attached thumbnail(s) |
clapeza |
Jan 12 2018, 07:06 AM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
The H4 housing upgrade is a perfect time to upgrade to LED bulbs as well! Brighter, whiter light, and less pull on the electrical system.
H4 Housings: http://shop.914rubber.com/H4-Glass-Housing...eg-bulbs-H4.htm LED bulbs: http://shop.914rubber.com/LED-Headlight-bulbs-H4LEDS2.htm |
Lo-Fi Version | Time is now: 19th April 2024 - 10:05 PM |
