Headlight question |
cedric9146 |
Jan 12 2018, 01:59 AM
Newbie Group: Members Posts: 18 Joined: 19-September 12 From: Belgium Member No.: 14,948 Region Association: Europe |
Hi guys, need your help !
I'm not a mechanic at all, but want to fix my car myself for once ! (IMG:style_emoticons/default/biggrin.gif) Driver side High beam is not working. All rest is fine. What could it be? (IMG:style_emoticons/default/confused24.gif) They are sealed beam lamps, so i presume the high and normal driving bulbs are inside, and you can not open it? So need to replace it with a complete new light? Fuses are ok. Removed the plastic cover and chrome ring. There is only one big plug connected. What is the small white wire for? I have read about replacing them by H4's . Is this just plug and play? Thanks for the help ! Cedric Attached thumbnail(s) |
mihai914 |
Jan 12 2018, 06:48 AM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Hi,
The white wire is your power to the high beam. You just need to put it back in the connector and it will most likely work. If you still have issues, you can try and swap the headlights from side to side just so you’ll know that you’re not dealing with a bad headlight. Going to H4s is a nice upgrade and not very expensive. Just be sure to buy quality. |
cedric9146 |
Jan 12 2018, 10:01 AM
Hi, The white wire is your power to the high beam. You just need to put it back in the connector and it will most likely work. (IMG:style_emoticons/default/huh.gif) I feel stupid (IMG:style_emoticons/default/biggrin.gif) |
bbrock |
Jan 12 2018, 10:59 AM
Hi, The white wire is your power to the high beam. You just need to put it back in the connector and it will most likely work. (IMG:style_emoticons/default/huh.gif) I feel stupid (IMG:style_emoticons/default/biggrin.gif) There should be a little tab on the back of the terminal on that white wire that you might want to GENTLY bend up just a little with a small standard screwdriver to help it lock into place in the plastic plug so it doesn't pop out again. But once that female terminal is on the blade of the bulb terminal, it will be secure, so don't sweat it if it still wants to pop out. |
Lo-Fi Version | Time is now: 24th April 2024 - 01:23 AM |
