Headlight question |
cedric9146 |
Jan 12 2018, 01:59 AM
Newbie Group: Members Posts: 18 Joined: 19-September 12 From: Belgium Member No.: 14,948 Region Association: Europe |
Hi guys, need your help !
I'm not a mechanic at all, but want to fix my car myself for once ! (IMG:style_emoticons/default/biggrin.gif) Driver side High beam is not working. All rest is fine. What could it be? (IMG:style_emoticons/default/confused24.gif) They are sealed beam lamps, so i presume the high and normal driving bulbs are inside, and you can not open it? So need to replace it with a complete new light? Fuses are ok. Removed the plastic cover and chrome ring. There is only one big plug connected. What is the small white wire for? I have read about replacing them by H4's . Is this just plug and play? Thanks for the help ! Cedric Attached thumbnail(s) |
clapeza |
Jan 12 2018, 07:06 AM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
The H4 housing upgrade is a perfect time to upgrade to LED bulbs as well! Brighter, whiter light, and less pull on the electrical system.
H4 Housings: http://shop.914rubber.com/H4-Glass-Housing...eg-bulbs-H4.htm LED bulbs: http://shop.914rubber.com/LED-Headlight-bulbs-H4LEDS2.htm |
cedric9146 |
Jan 12 2018, 10:05 AM
The H4 housing upgrade is a perfect time to upgrade to LED bulbs as well! Brighter, whiter light, and less pull on the electrical system. H4 Housings: http://shop.914rubber.com/H4-Glass-Housing...eg-bulbs-H4.htm LED bulbs: http://shop.914rubber.com/LED-Headlight-bulbs-H4LEDS2.htm LED is not allowed to pass the technical control here in Belgium. So the H4 setup is just with the same plug? |
Spoke |
Jan 12 2018, 02:13 PM
Jerry Group: Members Posts: 6,973 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
LED is not allowed to pass the technical control here in Belgium. I've known guys to change items on their cars (very wide rims and tires hanging outside the fenders and really loud or no mufflers) to stock items just to pass inspection. After the inspection, put the fun stuff back on. |
mepstein |
Jan 12 2018, 02:40 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
LED is not allowed to pass the technical control here in Belgium. I've known guys to change items on their cars (very wide rims and tires hanging outside the fenders and really loud or no mufflers) to stock items just to pass inspection. After the inspection, put the fun stuff back on. I saw a reply to that from another Belgium or Germany member, cant remember which, who said if they were in an accident, insurance would inspect the car and deny claim if they had non-approved parts. |
porschetub |
Jan 12 2018, 03:18 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
LED is not allowed to pass the technical control here in Belgium. I've known guys to change items on their cars (very wide rims and tires hanging outside the fenders and really loud or no mufflers) to stock items just to pass inspection. After the inspection, put the fun stuff back on. I saw a reply to that from another Belgium or Germany member, cant remember which, who said if they were in an accident, insurance would inspect the car and deny claim if they had non-approved parts. Yep same in my country,I will remove my LED headlights because the supplier mentioned they aren't quite legal here,I didn't ask why and don't know,could it be the shape of the beam or the brightness (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) . I will check the government pages and see why,all the other mods on my car have to be individually complied and listed on a metal plate riveted to the car. |
Lo-Fi Version | Time is now: 25th April 2024 - 06:33 AM |
