Removing CV Roll Pins |
Olympic 914 |
Jan 12 2018, 01:22 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
When I pulled the axles the roll pins stayed in the stub axles. they are blind holes so I can't push them out from the back and grabbing them with vice grips and prying has not budged them.
I am sure this has happened to others, What did you do? I guess drilling them would be an option, but wondered if there was another way. |
iankarr |
Jan 12 2018, 01:31 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I used a drill chuck. needs to be one with a key though. Just put the pin in the chuck and turn the key to tighten. it should compress the roll pin enough to remove it. Installation is the reverse...
Mueller |
Jan 12 2018, 02:28 PM
I used a drill chuck. needs to be one with a key though. Just put the pin in the chuck and turn the key to tighten. it should compress the roll pin enough to remove it. Installation is the reverse... Ditto on the drill chuck, can also use this method to remove dowel pins sometimes. |
Lo-Fi Version | Time is now: 26th April 2024 - 06:06 AM |
