Removing CV Roll Pins |
Olympic 914 |
Jan 12 2018, 01:22 PM
Group: Members Posts: 1,658 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
When I pulled the axles the roll pins stayed in the stub axles. they are blind holes so I can't push them out from the back and grabbing them with vice grips and prying has not budged them.
I am sure this has happened to others, What did you do? I guess drilling them would be an option, but wondered if there was another way. |
johnhora |
Jan 12 2018, 02:56 PM
Senior Member Group: Members Posts: 864 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Can you just leave them for when you’re reassembling the axles? (IMG:style_emoticons/default/agree.gif) Why do you want to remove them? |
Bartlett 914 |
Jan 12 2018, 03:10 PM
Advanced Member Group: Members Posts: 2,213 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Can you just leave them for when you’re reassembling the axles? (IMG:style_emoticons/default/agree.gif) Why do you want to remove them? His look to be in pretty good condition. If a cv has ever come loose, it is a good idea to make a cleanup cut in a lathe. When a CV comes loose, this surface will no longer be perfectly flat. You will find the surface near the holes to be a tad high. If this is the case, the CV will not stay tight! |
Lo-Fi Version | Time is now: 28th March 2024 - 04:03 AM |
