My Next Problem:, Headlight Wire Repair |
914_7T3 |
Jan 12 2018, 08:05 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
My car was purchased with nonworking headlights. Switched over to H4s with the initial tune up and there was rust in the buckets and the shop spent some time looking at grounds etc.. and got everything up and going.
Now that the car has been stripped for paint, I have learned that I am dealing with frayed headlight wires. As you can see the shielding is stripped/melted and wires are a bit of a cluster F-ck. Passenger side is worse. What is the best way to deal with this? (IMG:style_emoticons/default/confused24.gif) |
mihai914 |
Jan 12 2018, 08:21 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
How far does the damage go back?
One easy way to deal with it would be to find a good donor harness, take what is needed and splice it in your car. |
914_7T3 |
Jan 12 2018, 09:07 PM
How far does the damage go back? One easy way to deal with it would be to find a good donor harness, take what is needed and splice it in your car. It doesn't appear to run too far down the harness, but would want an experienced electric tech to take a look. Once spliced back in, is there a heat shrink shielding that can be used as well? I would use the same green color to keep it proper. FYI, I'm also a Montreal native! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:27 PM |
