Options to get Wider Track, crazy stupid 914 hack car |
nimblemotorsports |
Jan 13 2018, 01:54 AM
Newbie Group: Members Posts: 45 Joined: 12-January 18 From: Sacramento, California Member No.: 21,793 Region Association: None |
Hello, new guy here, I just picked up a donated 914 that is barely a roller, and will be used with a kitcar body and some offbrand junkyard motor/transaxle setup, for a super cheap road racer. To get this to look right, I need to use modern high negative offset wheels AND I need to widen the track width by 6 inches.
I know there are a lot of 'flared fender' 914s, this is probably a little wider than those, but can I just use 3 inch spacers to get the wider track? Seems a bit questionable for an actual road raced car. Not that I can afford good 3 inch spacers anyway. Here is one that looks wide enough, not sure what suspension is in this v8 car. (IMG:http://www.914world.com/bbs2/uploads_offsite/patrickms.s3.amazonaws.com-21793-1515830549.1.jpg) I am thinking I should just go ahead and replace entirely the front and rear suspensions with ones that have the right width. I actually have a couple Volvo v70 fwd suspensions that are just the right width and can put them in front and back with all the necessary tubing welding, etc, etc. Is there a simpler good cheap way. I need all three...simple, cheap, good. This isn't the body kit i'm using, but to give an idea why I need wider track. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-21793-1515830078.1.jpg) |
ablesnead |
Jan 14 2018, 10:11 AM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
Lets see ...super cheap road racer with modified drive train , junkyard motor with 500 horsepower.....I see an oxymoron in there somewhere ,,,
nimblemotorsports |
Jan 14 2018, 11:03 AM
Looking closer at the 914 rear suspension, I am thinking I can splice in an extension tubing in the swingarm to move out the wheel mounting. I really like how simple it is.
I just know if I fabbed up something that was the same people say it would never work, but HA! porsche did it, and they race these 914 right? I also had a Boxster I converted to an EV, and it has a very complicated rear setup, I'm surprised someone when to all the trouble to swap it into a 914, some real talent there. Studying the C5 pics, it looks like it may be too complicated also. I'm also building a mid-engine Audi V8 Corvair using a 944 suspension, and I have another 944 suspension and thought of putting it in the 914, but I think that is going into my Pinto. The 914 setup leaves a lot of room inside. Have attached pics of all the 914 you get for $200... lol Lets see ...super cheap road racer with modified drive train , junkyard motor with 500 horsepower.....I see an oxymoron in there somewhere ,,, Not an oxymoron, just a moron! lol But with turbos big HP is cheap. I may start with just 100 or 200 hp, but need to plan for the bigger engine. |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:05 AM |
