Options to get Wider Track, crazy stupid 914 hack car |
nimblemotorsports |
Jan 13 2018, 01:54 AM
Newbie Group: Members Posts: 45 Joined: 12-January 18 From: Sacramento, California Member No.: 21,793 Region Association: None |
Hello, new guy here, I just picked up a donated 914 that is barely a roller, and will be used with a kitcar body and some offbrand junkyard motor/transaxle setup, for a super cheap road racer. To get this to look right, I need to use modern high negative offset wheels AND I need to widen the track width by 6 inches.
I know there are a lot of 'flared fender' 914s, this is probably a little wider than those, but can I just use 3 inch spacers to get the wider track? Seems a bit questionable for an actual road raced car. Not that I can afford good 3 inch spacers anyway. Here is one that looks wide enough, not sure what suspension is in this v8 car. (IMG:http://www.914world.com/bbs2/uploads_offsite/patrickms.s3.amazonaws.com-21793-1515830549.1.jpg) I am thinking I should just go ahead and replace entirely the front and rear suspensions with ones that have the right width. I actually have a couple Volvo v70 fwd suspensions that are just the right width and can put them in front and back with all the necessary tubing welding, etc, etc. Is there a simpler good cheap way. I need all three...simple, cheap, good. This isn't the body kit i'm using, but to give an idea why I need wider track. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-21793-1515830078.1.jpg) |
Mark Henry |
Jan 14 2018, 06:02 PM
I'm confused.... (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Is the purple one your car? Those are GT flares, use the stock suspension. maybe beef it up a bit for higher HP. |
nimblemotorsports |
Jan 14 2018, 09:23 PM
I'm confused.... (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Is the purple one your car? Those are GT flares, use the stock suspension. maybe beef it up a bit for higher HP. Yes the $200 purple car is what I just bought for this project. Here is my $1 944 too, if you want more pics... oh that is on my phone, here is my corvair.... |
Mueller |
Jan 14 2018, 09:52 PM
I'm confused.... (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Is the purple one your car? Those are GT flares, use the stock suspension. maybe beef it up a bit for higher HP. Yes the $200 purple car is what I just bought for this project. Here is my $1 944 too, if you want more pics... oh that is on my phone, here is my corvair.... I take you've seen this car? Suspension from 2 different 911 series vehicles, I think he lives somewhere in the Bay Area as I've seen him at a few different car shows locally. http://www.streetmusclemag.com/news/classi...che-transplant/ |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:35 AM |
