Options to get Wider Track, crazy stupid 914 hack car |
nimblemotorsports |
Jan 13 2018, 01:54 AM
Newbie Group: Members Posts: 45 Joined: 12-January 18 From: Sacramento, California Member No.: 21,793 Region Association: None |
Hello, new guy here, I just picked up a donated 914 that is barely a roller, and will be used with a kitcar body and some offbrand junkyard motor/transaxle setup, for a super cheap road racer. To get this to look right, I need to use modern high negative offset wheels AND I need to widen the track width by 6 inches.
I know there are a lot of 'flared fender' 914s, this is probably a little wider than those, but can I just use 3 inch spacers to get the wider track? Seems a bit questionable for an actual road raced car. Not that I can afford good 3 inch spacers anyway. Here is one that looks wide enough, not sure what suspension is in this v8 car. (IMG:http://www.914world.com/bbs2/uploads_offsite/patrickms.s3.amazonaws.com-21793-1515830549.1.jpg) I am thinking I should just go ahead and replace entirely the front and rear suspensions with ones that have the right width. I actually have a couple Volvo v70 fwd suspensions that are just the right width and can put them in front and back with all the necessary tubing welding, etc, etc. Is there a simpler good cheap way. I need all three...simple, cheap, good. This isn't the body kit i'm using, but to give an idea why I need wider track. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-21793-1515830078.1.jpg) |
Justinp71 |
Jan 15 2018, 12:41 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
How much longer is the other body? Making it longer wheel base will alter the driving dynamics and you will need to move the transmission back as well. Also your shock mounting points will be in the wrong location if you plan to use those. Hopefully the new body is longer past the axle also? If you want to eventually have ~500hp I would suggest an LS or Subaru turbo motor. Audi 4 cyl turbo is another popular option. |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:57 AM |
