GB from 914Rubber water hoses like factory ! (3 of 200), Full set $20 all you need to replace the system |
Mikey914 |
Jan 13 2018, 04:15 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So thanks to a customer doing a high end restoration we made the rubber hoses like factory used. Others are offering a clear hose that is well... just not period correct.
The hose kit consists of the tire to male end connector (hose shown). The short hose to the cap The tank hose to stalk Stalk to T fitting hose 2 (one long one short) t fitting to squirter hoses I have them bagged in sections to help make it easier. One thing we did diferently was make the hose slightly thicker to give it more grip on the fittings. So you will not need to band them like factory did to get them to stay. They are a VERY tight fit and will require some soappy water to install on the fittings. These are not cheap silicone hoses, and have the correct gloss level. We did a limited run on these and onl have enough material for 30 sets on hand. Who's in? Attached thumbnail(s) |
Firstcar |
Jan 13 2018, 04:24 PM
Obsessive amateur mechanic Group: Members Posts: 97 Joined: 17-March 11 From: MA -South Shore Member No.: 12,831 Region Association: North East States |
I’m in for one set (IMG:style_emoticons/default/smilie_pokal.gif) Thanks Mark!
-Scott |
Mikey914 |
Jan 13 2018, 04:27 PM
I did make the hoses slightly longer than you need so you can cut to fit or use the extra material.
One mistake I made was to not tie a string adound the old hose on the way out. So I could pull the new one back up. Attached thumbnail(s) |
wes |
Jan 13 2018, 04:29 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I’m in but need to get with you on other items and ship together. I need to dig in my pile first. Thanks
bbrock |
Jan 13 2018, 04:50 PM
I'm in for one set.
branston |
Jan 13 2018, 05:00 PM
Member Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest |
I'm in too for 1 set - let me know how to pay
Mikey914 |
Jan 13 2018, 05:04 PM
I'll be getting these listed and sending out GB codes for the discount codes tomorrow morning.
Just sign up here I'll PM the code. |
jcambo7 |
Jan 13 2018, 05:06 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
I’m in for one!
yellowporky |
Jan 13 2018, 05:14 PM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
I will take one set please
dlee6204 |
Jan 13 2018, 05:22 PM
In
raynekat |
Jan 13 2018, 05:44 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I'm in please.
cn2800 |
Jan 13 2018, 09:52 PM
Member Group: Members Posts: 119 Joined: 11-August 14 From: Amarillo, Texas Member No.: 17,766 Region Association: None |
I'll need one set as well!
davehg |
Jan 13 2018, 11:48 PM
Member Group: Members Posts: 182 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
In for one set
rph20355 |
Jan 14 2018, 12:02 AM
Newbie Group: Members Posts: 16 Joined: 29-August 04 From: Washington, MI Member No.: 2,650 Region Association: None |
I'm in for a set.
mlmgm |
Jan 14 2018, 10:15 AM
Newbie Group: Members Posts: 35 Joined: 5-January 08 From: California Member No.: 8,536 Region Association: Northern California |
simonjb |
Jan 14 2018, 11:21 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
im in
Jett |
Jan 14 2018, 11:28 AM
Senior Member Group: Members Posts: 1,633 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I’ll take two Mark. We have used the plaice clear tubing and don’t like the look.
THANKS! |
Mikey914 |
Jan 14 2018, 02:08 PM
PMs sent to all so far. we do have a limited amount of material on hand for this so get it while it's hot.
Thanks, Mark |
80cap |
Jan 14 2018, 02:28 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
I'm in for one set!
Brian |
1adam12 |
Jan 14 2018, 03:53 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
Oh heck yeah! I'm in!!!!
Lo-Fi Version | Time is now: 25th April 2024 - 01:47 AM |
