| 1adam12 |
Jan 13 2018, 06:29 PM
Member ![]() ![]() Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
I've seen this ad on craigslist (Los Angeles) offering 914 help. Just wondering if this person Brian is a member here. Looking for some local help with my car but not going to spend $250 for a Porsche mechanic to just inspect it.
https://losangeles.craigslist.org/wst/cto/d...6416309419.html I need someone to recheck my valve adjustment, timing, dizzy and to bring a working MPS. I'm pretty sure I've screwed all this up as my 1.7l won't turn over now. |
1adam12 Craigslist 914 Mechanic Jan 13 2018, 06:29 PM
mgphoto Ok, lets start with your terminology?
Turn over, s... Jan 13 2018, 07:29 PM
1adam12
Turn over, ... Jan 13 2018, 07:45 PM
Mikey914 Sounds like you might get somefree advice as to we... Jan 13 2018, 07:31 PM
Montreal914 If it was running before you pulled out the distri... Jan 13 2018, 08:45 PM
1adam12
If it was running before you pulled out the distr... Jan 13 2018, 08:55 PM
r_towle You are near Los Angeles.
Go find a local VW airco... Jan 13 2018, 09:00 PM
914werke Thank you Montreal914 and Mark for the support. I... Jan 13 2018, 09:45 PM
Tom_T Near-ish to you in OC, you can try either Bill Bre... Jan 13 2018, 09:48 PM
thelogo Ive seen the same add
And it seems to good to be... Jan 13 2018, 09:59 PM
Mueller
And it seems to good to b... Jan 14 2018, 01:06 PM
thelogo
[quote name='thelogo' post='2567945' date='Jan 13... Jan 14 2018, 01:26 PM
get off my lawn
How do you get to know someone well without mee... Jan 18 2018, 06:00 PM
Tdskip Do you feel comfortable with the idea of static ti... Jan 13 2018, 10:55 PM
KELTY360 Have you called him to see if he's a member he... Jan 13 2018, 11:19 PM
Andyrew If that was on my local craigslist you can guarant... Jan 14 2018, 01:35 AM
r_towle The car is running a vw bus motor, so it’s fairl... Jan 14 2018, 09:56 AM
76-914 Be sure that the molex plug at the Dist hasn't... Jan 14 2018, 11:42 AM
914_teener Maybe I can help you out.
I'm in Glendora and... Jan 14 2018, 01:00 PM
bdstone914 I have not heard of him before. I could suggest a... Jan 14 2018, 11:01 PM
Larmo63 :agree:
Bruce helped me out A LOT when I was try... Jan 15 2018, 01:03 AM
bdstone914 Looking more at the ad I would probably not use wh... Jan 15 2018, 07:30 AM
craig downs I live in Eastvale which is close to you. I'm ... Jan 15 2018, 12:02 PM
7TPorsh What kind of points setup in the dizzy? Is it per... Jan 16 2018, 10:46 AM
1adam12 Thanks to everyones input here, I really appreciat... Jan 16 2018, 03:00 PM
snakemain Odd coincidence with the "Oh Happy Day" ... Jan 16 2018, 08:45 PM
nimblemotorsports right off the bat, I'd say DO NOT use this guy... Jan 17 2018, 07:32 PM
Front yard mechanic
right off the bat, I'd say DO NOT use this gu... Jan 18 2018, 08:13 AM
1adam12 FINALLY! FINALLY! FINALLY! Got her ru... Jan 18 2018, 03:07 PM
The Cabinetmaker Sometimes its the simple things in life that give ... Jan 18 2018, 03:37 PM
cmxiv 74 Hi, Good you fixed your problems. My opinion about... Feb 5 2018, 02:43 AM
Lucky9146
Hi, Good you fixed your problems. My opinion abou... Feb 5 2018, 09:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:11 AM |
